Popping threw exhaust - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-04-2012, 09:38 PM Thread Starter
06kingranch37's Avatar
Ok my truck pulls like a son of a gun low end but once the rpms get to 2800 or above you can hear a popping threw the exhaust would that be the injectors and you can really hear it if you rev the truck up in Park any info would be great oh and everything that's done to the truck is in my sig
2006 f350 has 205/100 warren injectors custom fuel system a1000 regulated return, s368 batmowheel , banks tecnicooler,58v ficm, afe intake, single 7 inch miter stack 35 12.50 18 toyos, elite stage 1 camshaft, sct live wire with warren diesel tunes, 4 inch lift kit ,
06kingranch37 is offline
post #2 of 8 (permalink) Old 06-04-2012, 11:53 PM
justind's Avatar
Re: Popping threw exhaust
We could start with the worst, messed up valvetrain.
05 F350 CCSB 6.0, 4" MBRP, SCT/Looney, CTS, 275
Rugged Terrains
justind is offline
post #3 of 8 (permalink) Old 06-05-2012, 12:11 AM
oldbluef250's Avatar
I would start by taking the valvecovers off and see if there is a broken roker arm
2003 F350 cclb 6.0
oldbluef250 is offline
post #4 of 8 (permalink) Old 06-05-2012, 12:22 AM Thread Starter
I was hoping that it wasn't going to be in the valve train
post #5 of 8 (permalink) Old 06-05-2012, 12:26 AM
Kbryant777's Avatar
Hopefully if it is valve train you don't have to replace a head. $1250 a piece. I just replaced 2 because they were cracked.
[B]2005 F250 King Ranch
Studs,egr delete, regulated return,RCD 68powermax, banks CAI,FICM tunes from PHP, Tuned by Eric
Kbryant777 is offline
post #6 of 8 (permalink) Old 06-05-2012, 12:53 AM
a broken rocker is cheap, if thats the problem.
2003 F350 cclb 6.0
post #7 of 8 (permalink) Old 06-05-2012, 01:20 AM
stroker57's Avatar
my truck dose the popping threw the exhaust but only when i first start it and run maybe 5 min then stops and runs fine would that be valve train or something eles ?
some parts to try and go fast
stroker57 is offline
post #8 of 8 (permalink) Old 06-05-2012, 03:51 AM Thread Starter
I don't think it's the rockers cause I just did injectors about 1 month ago none looked broken could a valve spring or burnt valve cause it
