edge cts ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-01-2012, 01:25 AM Thread Starter
6.0stroken's Avatar
edge cts ?'s
im looking to get the best scanner so i can see whats wrong with my truck. also can the edge cts insight read hpo pressure for my truck?can it read fuel pressure? i have an 04 with late 04 engine with icp on the valve cover. would a auto engunity with ford bundle be better than edge as far as reading parameters.
04 f-250 quad cabin 4x4 auto 5r110, 190cc 100%, upgraded oil cooler, upgraded fuel spring regulator, 6.4 banjos, airdogII, gogo's direct clutch solenoid, 5'' exhaust with no cat, sct 3015 with xrace,xstreet,looney wild,srl+,ddp,rcd,super panty dropper, arp headstuds, sinister coolant filtration, sinister egr delete, moderate tuned 58v ficm.
6.0stroken is offline
post #2 of 5 (permalink) Old 06-01-2012, 01:28 AM
ajfetterman's Avatar
Re: edge cts ?'s
I would go with AE if I had to do it over.
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
ajfetterman is offline
post #3 of 5 (permalink) Old 06-01-2012, 01:33 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: edge cts ?'s
Yea if you're looking for a diagnostic tool, I would get an AE over the CTS but if you want (IMO) the best gauge display out there that can be set up to monitor just about everything you want to while running, then I would get a CTS.
Just know that the CTS and AE can not in stock form monitor fuel pressure. You have to set up the CTS to do that and the AE can not but the AE can do A LOT of things that the CTS can not like cylinder power balance tests, monitor exhaust back pressure, etc. It really comes down to if you want a diagnostic tool or a monitoring device. Hope this helps.
Nate
windrunner408 is offline
post #4 of 5 (permalink) Old 06-01-2012, 09:43 AM Thread Starter
6.0stroken's Avatar
Re: edge cts ?'s
I ordered a ae lastnight hope it gets here soon. Can it monitor hpo?
post #5 of 5 (permalink) Old 06-01-2012, 03:37 PM
Re: edge cts ?'s
Yes it can. The thing to keep in mind though is that it is pulling all of its info from the OBDII port. So for HPO pressure (injection control pressure) to be read accurately, you are gonna need to have the truck on its stock tune.
Nate
