air dog 2 use stock ford fuel filters?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 05-31-2012, 12:37 AM Thread Starter
does the air dog 2 use any of the ford fuel filters or does it completly eliminate the stock fuel system?
what a mess is offline
post #2 of 24 (permalink) Old 05-31-2012, 02:57 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: air dog 2 use stock ford fuel filters??
It can eliminate the stock fuel system but it doesnt do it automatically. It only eliminates the stock pump and filter on it. You can either use the filter on the motor or remove it and the stand pipe and get rid of the OEM filters. You can also delete the fuel bowl and run lines directly from the pump to the heads.
Nate
windrunner408 is offline
post #3 of 24 (permalink) Old 05-31-2012, 03:01 AM
'05 Excursion
Term3's Avatar
Have a read.
AD2
Term3 is offline
post #4 of 24 (permalink) Old 05-31-2012, 02:09 PM Thread Starter
ive got a rr kit alrdy if that helps any so you are saying i can just hook it to my kit and elimonate all factory fuel nice sence air dog fuel lines are bigger correct>? i have got my air dog yet now sure what system i should rune sencei have regulator on the rr kit of corse and pressure at the motor would be more accurate than pressure at the pump correct?
post #5 of 24 (permalink) Old 05-31-2012, 02:29 PM
PursuitInterceptor
HeavyAssault's Avatar
Why not use an AD150?? Throw in a tank sump...done deal.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #6 of 24 (permalink) Old 05-31-2012, 04:13 PM Thread Starter
yesum thats what im trying to figure out but rnt you worried about the sump getting ripped off sence im not just on the road i might be in a field or in the woods dont you worry that the sump will get ripped off ? and if i go with the 150 will it come with enough fuel line to go all the way to the rr kit or will i have to get more sence i would liek to eliminate the hole factory system or it makes more sence to i think heh it looks like it just connects to the fuel pump on the rail in the install pics
post #7 of 24 (permalink) Old 05-31-2012, 04:18 PM
'05 Excursion
Term3's Avatar
Check this thread out.
AD2
And
More AD2
Term3 is offline
post #8 of 24 (permalink) Old 05-31-2012, 04:25 PM
06-6.0 stoker's Avatar
Do you not need a sump with an air dog 2?
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #9 of 24 (permalink) Old 05-31-2012, 04:27 PM Thread Starter
alright so sence i have rr kit i should jsut get a 150 and a sump ok so now is the larger fuel line something i can get at parts store or shoudl i get it from air dog? sence i want to just go directy to the rr kit from the air dog and leave stock system complete for a back up incase something goes wrong with the air dog pump
post #10 of 24 (permalink) Old 05-31-2012, 04:28 PM
PursuitInterceptor
I had my skid plate modded and the sump/lines are protected. You really need to decide how you want the kit run. You already have the back half.
For a ADII you still need to buy all the front lines, Y , and fittings to feed the fronts.
If you used the AD150 it has everything already in the kit. The AD 150 feeds the OEM pump so the front lines are all OEM.
It's another way to skin that cat. We all agree increasing the fuel pressure and quality is of great benefit for the injectors. HOW it's done is were the differences come in to play.
You can rip out all the OEM stuff or use it.....$.02
You dig.
