snap on part #SRD35 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-29-2012, 02:51 AM Thread Starter
teambluemxer's Avatar
snap on part #SRD35
so is there any thing i need to know about this adapter like do i need to set the wrench higher to reach my ft/lbs. or can i just set it normal and be good?
2000 7.3 ccsb 4x4 dp-tuned.ww. n some other. SOLD
2003 6.0 eclb. 250/100s stg1 colt and s366fmw built trans
teambluemxer is offline
post #2 of 4 (permalink) Old 05-29-2012, 02:53 PM
Crazy Canuck's Avatar
Re: snap on part #SRD35
Look into correct torquing procedures on the Internet. What you will find is that if you put it at 90degree angles from your torque wrench than no changes to the torque value, if used in line then it will add or subtract from torque. With using a torque wrench distance and angles are VERY important. 1 foot from the bolt pulling at 90 degrees = foot pound. If you put the adapter in line and it takes you a greater distance than the 1 foot then you have to start adding this value. Eg if the handle on your wrench is 1foot long and your adapter is also 1 foot long then if you put them in line you double your torque if you put gthe wrench at 90 degrees the the distance from the handle does not change to the bolt and your torque value remains the same if you put the handle of the wrench in line but backwards so the handle is now over your bolt you can pull to the cows come home but you will not actually tighten any thing . Sorry for the long exanation. Hope it helps.
2011 F350 CC Dually, Lariat, ultimate package PSD, lock pick, line x, weather guard x box. Pic in avatar.
2000 xcab F250 PSD 4x4 not even close to stock, broken Feb 2011 (collision, write off)
Crazy Canuck is offline
post #3 of 4 (permalink) Old 05-29-2012, 02:57 PM
matt
mgeistman's Avatar
Yeah!!! Now thats a torquing wright up right there!!!! Thanks man!
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #4 of 4 (permalink) Old 06-05-2012, 02:36 AM Thread Starter
Random Links there an easy calculator.
