rev-x? and best out to use in next oil change? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 05-28-2012, 10:29 PM Thread Starter
hello all ive been useing motor craft 15-40 oil and filter sence i got the truck but is there a better oil to use and is it worth useing rev-x? and does anyone know if it increases gas milage? thank you all for your input
what a mess is offline
post #2 of 22 (permalink) Old 05-28-2012, 11:18 PM Thread Starter
Re: rev-x? and best out to use in next oil change?
i ment to say best OIL to use
post #3 of 22 (permalink) Old 05-28-2012, 11:21 PM
matt
mgeistman's Avatar
rev-x is good stuff. imo no its not worth it. any good 5w-40 oil will work great for stiction. keep using the same filter though! theres a sticky posted at the top of the form about ''PHP's rev-x findings'' in a 6.0 powerstroke. hope this helps
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #4 of 22 (permalink) Old 05-28-2012, 11:35 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
To give a little perspective on what I have noticed, I have used Amsoil 15w-40 up until a year ago and I have used it since my first oil change on the truck and I have had the truck since it had 4 miles on it. Well I switched to 5w-40 Amsoil and noticed that the truck ran a little quieter and didnt lope as bad when it was cold out. Then I added in some rev-x and the truck would start and run great at temps as low as 18F (I havent been able to test below that). Rev-X is definitely some snake oil that has actually done what it claimed to be able to do but it IS expensive. I also have not been able to see any real gains in MPG. For the money I would only run it in the winter if you decide to run it at all and right now I am trying this stuff called Archoil AR9100. It is much cheaper than Rev-X and so far seems to be doing just as good of a job. I am going to keep running it because it is about 1/3 to 1/2 the price of Rev-X. It can be found at Archoil brings advanced solutions to lubrication, fuel and corrosion. Nanoborate grease, Nano Borate Oil, Nano Particles, Corrosion, Rust, MotorSilk, LubriSilk,Turkey, Biodegradable Engine, Motor Treatment Lubricants, Motor Silk, Boron CLS Bond Lubricants - Evergreen America Corporation
I should note that I recommend switching to a high quality synthetic 5w-40 oil and keep using the motorcraft filters. Hope this helps.
Nate
windrunner408 is offline
post #5 of 22 (permalink) Old 05-29-2012, 12:14 AM
Extended Power's Avatar
I have used Amsoil Series 3000 5W/30 for only gawd knows how long.
Even as a preferred customer, it's still too expensive.
I just pulled my injectors out, had them rebuilt into bigger units, and also pulled out my oil cooler for some modifications for a second hpop...
Drained and sucked out all the Amsoil Series 3000, and replaced with Shell Rotella T6 synthetic.
Half the price of Amsoil...I hope the T6 stuff is good enough...
2003 F-350 KingRanch 4x4
Extended Power is offline
post #6 of 22 (permalink) Old 05-29-2012, 12:38 AM
What about the Mobil 1 5w40 Full Synthetic? I have been using Mobil 1 Filter. THanks
jaredb is offline
post #7 of 22 (permalink) Old 05-29-2012, 12:45 AM
I think Mobil 1 would be fine to use.
Nate
post #8 of 22 (permalink) Old 05-29-2012, 12:59 AM
strokin6L's Avatar
mobil 1, and Valvoline premium blue extreme is good stuff. I'm like Ivan, i've been using Amsoil for a very long time...series 3000 5w-30 and the 5w-40. I have no complaints with the amsoil and i'm also a preferred customer and get it at a lower price, but like Ivan said...it's still pricey. I think with tax and shipping for 4 gallons of 5w-40 and a Eabp100 by-pass filter came to around $175. I also use Archoil's AR9100 friction modifier in the oil. I use to run the rev-x, but this stuff is half the price and does the same thing.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #9 of 22 (permalink) Old 05-29-2012, 01:31 AM
siksix0
Where can u get it?"
05 six0 cc shortbed lariat FX4, harley headlights,recon cab lights, egr/oil cooler delete, sct x3(gear head custom tunes), 03 turbo with batmowheel, arp studs, airaid intake, zoodad mod, straight duals w/ 6" tips, php tuned ficm, six4 banjos and blue spring fpr kit
415rwhp/750 ft lbs trq (loaded mustang dyno)
05bbn is offline
post #10 of 22 (permalink) Old 05-29-2012, 01:35 AM
Ever Green America
Nate
