GOGO direct clutch solenoid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 05-28-2012, 02:05 AM Thread Starter
jhunter14's Avatar
Which solenoid do I take out and replace?
Because I know there are 6.
Thanks
2006 F-250 XLT 6.0L 4x4 CC Auto, 8X,XXX miles: 6.4 banjos, RR blue spring, ARP's, EGR delete, STC update, digital FP gauge, SCT Livewire TS, coolant filter, S&B CAI, CFM Smallmouth, 5" straight pipe with 8" tip. Updated turbo feed/drain.
jhunter14 is offline
post #2 of 24 (permalink) Old 05-28-2012, 02:18 AM
matt
mgeistman's Avatar
Re: GOGO direct clutch solenoid
there are 7 solenoids total.theres a row of three and a row of four. its the middle one in the row of three. the row of three will be closet to the T/C.
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #3 of 24 (permalink) Old 05-28-2012, 12:26 PM Thread Starter
jhunter14's Avatar
Ok. I see there are 7.. I pulled the middle of the front 3 out.. The solenoid they sent me will not fit..
I don't know how to add a pic from my phone. But on the stem side of the solenoid against the base where it seats, there is a raised line, looks like to keep it from spinning.. The line on the one that came out of my truck and the modified one i received don't line up...
post #4 of 24 (permalink) Old 05-28-2012, 01:04 PM
Sponsor
04stroker's Avatar
Spin the solenoid. The modified one fits at a different angle.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #5 of 24 (permalink) Old 05-28-2012, 01:05 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Well I know the factory solenoid goes in with the electrical connector pointing straight down but these solenoids have to go in with that connector moved to one side or the other in order to get it to fit in. Not sure if that is your problem or not but hope it helps. Take care.
Nate
windrunner408 is offline
post #6 of 24 (permalink) Old 05-28-2012, 01:06 PM
Wow beat me to it. Yes this is what I am referring to.
Nate
post #7 of 24 (permalink) Old 05-28-2012, 01:21 PM Thread Starter
jhunter14's Avatar
Well my issue is those two grooves. My solenoid that came out are off centered. The modified one is in the center. Looking in to where it seats in the trans there are only those two grooves and spinning The new one still won't let it seat in position to get the clip back on..
post #8 of 24 (permalink) Old 05-28-2012, 01:23 PM
Sponsor
04stroker's Avatar
It will I think you rotate the connected towards the passenger side not sure on that. But when installed it will be at a different angle than all the others.
holdersdiesel.com
post #9 of 24 (permalink) Old 05-28-2012, 01:26 PM Thread Starter
jhunter14's Avatar
Ok Ill give her a whirl. Gotta drain and pull the pan again it got late last night and just assumed it was the wrong one..
post #10 of 24 (permalink) Old 05-28-2012, 02:49 PM
Sponsor
04stroker's Avatar
Yea you would not believe the amount of people that call the shop thinking its the wrong one.
holdersdiesel.com
