just did my own ccv mod wondering if its correct - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-28-2012, 01:05 AM Thread Starter
hello all i just did my own ccv myself cost 10 bucks i just cut all of the old tubing off the 90 deg ccv elbo that goes in the cc itself and put 1 in heater hose on it and went strait down to the outside of frame rail and ziptied it to the bumper mount because i read the least amount of hose the better and i used a electrical box round cover and some rtv black gasket maker to seal the hole in cai tube is that alright or should i change it? thank you all
what a mess is offline
post #2 of 5 (permalink) Old 05-28-2012, 01:13 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: just did my own ccv mod wondering if its correct
By the way, love your screen name
Stock
PowerstrokeJunkie is offline
post #3 of 5 (permalink) Old 05-28-2012, 01:18 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
You'll probably be ok with that. I used JB weld and some thin cardboard (like off of a toilet paper roll) to plug the hole. It isnt really subjected to any pressure so I am sure you will be ok.
Nate
windrunner408 is offline
post #4 of 5 (permalink) Old 05-28-2012, 08:50 AM
Sounds good to me.
2006 F250 with 35x13.50 18 MTZ'S, S&B intake, Sinister egr delete, banks CAC tube with intake, blue spring upgrade, high idle switch, ccv mod, fp gauge, cat/muffler delete, 6" rough country lift, SCT tuned by RCD, RCD 155/30% injectors, Airdog 100. 9.18 1/8th mile.
Joshbaker is offline
post #5 of 5 (permalink) Old 05-28-2012, 02:05 PM
Extended Power's Avatar
I used a 3/4" pipe plug and siliconed it into the intake. It was a tight fit, but worked 100%.
I also used 1" heater hose and ran it just past the cab so I couldn't smell anything afterwards.
Sounds like you did it right...congrats!
2003 F-350 KingRanch 4x4
Extended Power is offline
