Insight CTS monitor parameters?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-27-2012, 04:14 PM Thread Starter
scastillo813's Avatar
I installed my Edge Insight CTS and my oil temp and coolent temp stay about with 5* of each other. Any advice on what my other parameters should be? I'm going to do the egt monitor when I get the other engine work done(egr delete, oil cooler, studs, ect). Thanks
2005 KR CC 6.0
7" PROCOMP, 20x10 motometal, 35x12.5 Toyo M/T, 4" mbrp turboback, S&B intake, sct tunes, bluespring-6.4 banjo's, 5w-40syn, ect
scastillo813 is offline
post #2 of 10 (permalink) Old 05-28-2012, 02:38 AM Thread Starter
Anyone??
2005 KR CC 6.0
post #3 of 10 (permalink) Old 05-28-2012, 02:46 AM
matt
mgeistman's Avatar
Re: Insight CTS monitor parameters??
5* is great!! what other parameters are you wondering about? you need to be specific if you want answers
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #4 of 10 (permalink) Old 05-29-2012, 01:35 AM Thread Starter
Injection control pressure, injector pulse width, manifold abs pressure, intake temp, mass air flow.
I also saw that its throwing the code P0279 cylinder #7 injector circuit low. Any thoughts?
2005 KR CC 6.0
post #5 of 10 (permalink) Old 05-29-2012, 01:52 AM
matt
mgeistman's Avatar
whoo boy Nate i need you on this one!!! lol
post #6 of 10 (permalink) Old 05-29-2012, 01:54 AM
matt
mgeistman's Avatar
on the number 7 its prolly going bad. dosen't miss at all? most of the time it would be #8
post #7 of 10 (permalink) Old 05-29-2012, 01:55 AM
matt
mgeistman's Avatar
i dont use a cts so hopfully he will chime in
post #8 of 10 (permalink) Old 05-29-2012, 02:08 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Ok let's see here. ICP wont be accurate if you're tuned and will vary significantly based on oil temp. When everything is good and hot, at idle it should be right around 600, 12-1500 cruising and like 4000psi at WOT. This is of course with stock tuning or other tuning that allows the ICP value to be read properly from the OBDII port. I have no idea on PW. I usually see values in the 1.?? something like 1.1-1.3 for most of my driving when I was on stock sticks. I havent checked with the bigger injectors. MAP should be boost plus 15psi. IAT1 should be right at or less than ambient by a couple degrees. I have never monitored IAT2. I also got nothing on MAF readings. Hopefully some others can chime in here to help out and correct me and/or give more info. Sorry I cant be of more help.
Nate
windrunner408 is offline
post #9 of 10 (permalink) Old 05-30-2012, 05:09 AM
EOT/ECT will let you observe indirectly the condition of your oil cooler (you want these values to remain within 15 degrees of each other) at 10* i think your cooler are getting plugged, mine run ECT 192-194* EOT 200* and pulling my 5er up a 7% grade about 6mi long in 95* weather ECT 218* EOT 228* and the fan sounds like a jet plane and it turns on around 212-214*
FP so you can protect your fuel injectors (stay between 45 and 70 psi) Mine before reg spring kit 50lbs idle WOT 44lbs after 62-64lbs idle 58lbs WOT my injectors love it.
EGT to stay below 1300 degrees F so you don't melt metal components you can go to 1500* for a very short time.
TFT Max 185*- 200-220* Trouble
FICM---Must be a +45volts 48.5 volts just right
ICP---Must have 500lbs to start, run 1100 to 1350lbs cold, Idle hot 580lbs and hot 3800 to 4000lbs at WOT
ICPv--0.8-1.6
VGT--15% to 85%
Boost--Max 28lbs on a stock motor
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
post #10 of 10 (permalink) Old 05-30-2012, 11:37 AM
Whew, thanks man for the help.
Nate
