um studding truck? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 58 (permalink) Old 05-27-2012, 03:28 PM Thread Starter
teambluemxer's Avatar
um studding truck?
idk if this is thr right area to post this but does 5k sound like a good price to get truck studded at a shop im in medina ohio would love to get it studded for under 3k! only been to one shop 5 is way to high right?
teambluemxer is offline
post #2 of 58 (permalink) Old 05-27-2012, 03:40 PM
04stroker's Avatar
Re: um studding truck?
5k is a little high. We usually do studs,egr delete, coolant filter, oem head gaskets, all new top end gaskets, head machining and all for a little less than that.
04stroker is offline
post #3 of 58 (permalink) Old 05-27-2012, 04:23 PM Thread Starter
yea i already have all of that except for studs and gaskets i got all my stuff from you through patrick.
post #4 of 58 (permalink) Old 05-27-2012, 06:27 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Are your head gaskets actually blown?? If they are not, I would recommend just paying $400 for some studs and swapping them out yourself one at a time and torquing them down to spec. You would have to move some stuff around in the engine compartment but you could get er done with some time, patience, a good socket/wrench set, and a torque wrench. That would save A LOT right there.
Nate
windrunner408 is offline
post #5 of 58 (permalink) Old 05-27-2012, 06:32 PM
04stroker's Avatar
Oh cool deal. Yea that's waaaay high for just studs.
post #6 of 58 (permalink) Old 05-27-2012, 10:25 PM Thread Starter
can they actually be done 1 at a time!?!?! mine ARE NOT blown
post #7 of 58 (permalink) Old 05-27-2012, 10:33 PM
Yes they can! As I mentioned above, you have to move some stuff out of the way like the heater core box on the passenger side of the firewall and you might have to "massage" the fire wall some because the bolts/tools MAY hit (I have heard of guys that didnt have any contact whatsoever); but either way, if pull a head bolt out and replace it with a stud that is torqued to spec, it most certainly can be done and there are plenty of folks running studs this way with great success. If I would have thought about it more when I did my head gasket job, I would have went this route to begin with. Ask Jeremy (lubeowner) about this and he can give you the skinny on it a little better probably. I would think this could save a few thousand for other and more important things
Nate
post #8 of 58 (permalink) Old 05-27-2012, 11:07 PM
matt
mgeistman's Avatar
mine is done one at a time and is holding over 55psi boost and not a single drop out of the degas bottle. it works as long as your heasd are COMPLETELY FLAT!! also i torqued mine to 255 twice!!!!
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #9 of 58 (permalink) Old 05-27-2012, 11:31 PM Thread Starter
i have a very tiny amount of white dried it looks like on the degas bottle is that a no go for 1 at a time?
post #10 of 58 (permalink) Old 05-27-2012, 11:40 PM
matt
mgeistman's Avatar
Man the best thing you can do is hook up a pressure gauge and drive the #### outta it. If heads lift even a little it will be a dead give away. That's what I did with mine. Coolant pressure never got over 13 lbs so I said #### it and took the chance. I torqued the piss out of the studs though.
