Need your help / opinion? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-27-2012, 03:19 PM Thread Starter
Hey guys,
Just finished my time in the service and moved back home to Northern NJ. Buying my first 6.0L in a couple weeks, and wanted to get your thoughts.
Its a 06 crew cab lariat FX4 with 116k on it. I had a shop look it over and they couldnt find anything wrong.
What are your recommendations on some first maintenance / mods that should be taken care of first to prevent common issues with this motor?
I appreciate your thoughts and opinions.
Thanks again!
06pwrstrk is offline
post #2 of 5 (permalink) Old 05-27-2012, 03:27 PM
whistle tits
ghohouston's Avatar
Re: Need your help / opinion?
Change all fluids and filters unless they just look brand new
ghohouston is offline
post #3 of 5 (permalink) Old 05-27-2012, 06:52 PM
Welcome and thanks for your service.
Install a coolant filter
Get some gauges like the Edge CTS, CS or ScangaugeII
Fuel pressure gauge, pressure under 45lbs at WOT kills injectors
Use only Ford or Racor filters, use a 5w40 Syn oil
Do alot of reading.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
post #4 of 5 (permalink) Old 05-27-2012, 07:00 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Aside from changing out the filters with FORD Motorcraft filters, some good synthetic oil like either Amsoil or Mobil 5w-40 is gonna be your best place to start. Then I personally would get an Edge CTS to monitor your oil and coolant temp delta to make sure all is good there as this device can be expanded later on when you want/need to monitor more things like EGTs and fuel pressure and whatever else you want to. Then depending how everything pans out with that you can look to add power but first get all of the reliability taken care of first and whatever you do, do not get anything for more power but a SCT with some custom tunes.
Nate
windrunner408 is offline
post #5 of 5 (permalink) Old 05-28-2012, 01:11 AM Thread Starter
I appreciate the input guys, thanks!
