trans ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 05-26-2012, 11:53 PM Thread Starter
stroker57's Avatar
trans ?
i just got the new diesel power mag and seen mpd put a 4r100 in place of a 5r110 in there 6.4 as anyone done this with a 6.0 seems like a good idea
some parts to try and go fast
stroker57 is offline
post #2 of 25 (permalink) Old 05-27-2012, 12:03 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: trans ?
Did the magazine say why they swapped the 4r100 in over the 5r110?? Unless they know something and arent sharing, from everything I have read I wouldnt know why they would do this as the 5r110 is a much stouter unit (at least in the stock configuration) and therefore doesnt seem like a good idea to me. Hence why I would like to know their reasoning.
Nate
windrunner408 is offline
post #3 of 25 (permalink) Old 05-27-2012, 12:37 AM Thread Starter
stroker57's Avatar
Re: trans ?
the mag said the 4r100 was built buy BTS and laid down 40 more hp on the dyno just because of the trans hes running a big single turbo mag says it quicker faster and more reliable than a 5r110
post #4 of 25 (permalink) Old 05-27-2012, 01:46 AM
Re: trans ?
I guess it makes sense if the truck was only going to be a dyno and/or competition truck so it would never have an overdrive because it would definitely keep the engine rpms up so the turbo would light quicker. I dont see for the need for VAST majority of everyone else who drive their truck on the street and/or tow with it. JMO.
Nate
post #5 of 25 (permalink) Old 05-27-2012, 01:47 AM
i like to party
pizza pig's Avatar
Re: trans ?
This is not the case in a 6.0, the 6.4 uses a ECM to tune the motor and a separate TCM to tune the transmission, the 6.0 uses a combination ECM/TCM. The 6.4 has significant lag in the software that can only make a 6.4 5r shift so fast without making some hard part modifications, and even then I couldn't tell you where the fine line is. Elite is making them last on those trucks.
The 5r also uses solenoids to electronically control the shifts. The 4r does not, and will create a perfect shift every time, it also has the ability to lock the converter in 1st gear, great for the strip, I dont know if i'd be putting one in a street truck, but craig doesn't seem to have any problems daily driving it.
on a 6.0, I honestly think its a waste of breath to swap in the 4r if you have someone good build the 5r. There are plenty of trucks putting down PLENTY of power with a 5r on the 6L.
pizza pig is offline
post #6 of 25 (permalink) Old 05-27-2012, 01:48 AM
matt
mgeistman's Avatar
Re: trans ?
intresting???? is it a better buite tranny?
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #7 of 25 (permalink) Old 05-27-2012, 01:50 AM
matt
mgeistman's Avatar
Re: trans ?
built
post #8 of 25 (permalink) Old 05-27-2012, 02:02 AM
Re: trans ?
Interesting note Greg. Thanks for the insight. If this is indeed the way it all works I can see why the 6.4 guys would do it but I am with you on the fact that I like my 5r and dont really want to drop any money for a 4r.
I dont think it is a better built tranny.
Nate
post #9 of 25 (permalink) Old 05-27-2012, 02:21 AM
bracketracer's Avatar
Re: trans ?
Could you clarify this? I assume you meant if you are manually shifting the trans, not leaving it in drive and letting it shift itself?
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #10 of 25 (permalink) Old 05-27-2012, 02:34 AM
i like to party
pizza pig's Avatar
Re: trans ?
No im not talking about manually shifting the transmission, the 4r uses a valve body to apply line pressure from the pump to the clutches. The 4r is old school, but it works and works well. The solenoids are very temperamental and sensitive to foreign material, and eventually wear out.
