New 6.0 Truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-26-2012, 07:13 PM Thread Starter
New 6.0 Truck
Im looking at buying at 6.0 truck. What are the must things I should do to the truck when I get it. Has 80,000 on it completely stock.
Who are the right companies to use to get the best performance?
My budgets in the 2000 to 2500 range.
I have always done all my own work on my 7.3 looking to do the same on new truck.
Thanks for any input.
jaredb is offline
post #2 of 4 (permalink) Old 05-26-2012, 09:09 PM
06-6.0 stoker's Avatar
Re: New 6.0 Truck
Start with a good set of gauges, coolant filter kit, change oil and all filters
To get some performance go with a custom tuned sct
I picked innovative diesel for my tunes and love them, there's a lot of other good places
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #3 of 4 (permalink) Old 05-26-2012, 10:22 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: New 6.0 Truck
Edge CTS for monitoring everything right off the bat and this way you can see how doing stuff affects your motor and/or where you need to focus your efforts. $600 w/pyro.
Oil Change $100
4in turbo back exhaust $500-$600 bucks
Now depending on what your EOT and ECT are doing (i.e. could be saying you need a new oil cooler) I would spend the rest of the money swapping out the oil cooler if necessary and doing head studs.
If not then GREAT and either way I would delete the EGR, get a SCT w/custom tunes, and (provided your head gaskets are still sealing [you can check that with a 0-15psi gauge]) I would buy a set of ARP head studs for $400 and stick them in one at a time.
Hope this helps man. Best of luck.
Nate
windrunner408 is offline
post #4 of 4 (permalink) Old 05-28-2012, 04:39 PM Thread Starter
Re: New 6.0 Truck
Thanks guys
jaredb is offline
