fuel pressure question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-25-2012, 10:50 PM Thread Starter
i have a Regulated Return Kit and it eliminates the blue spring so what should i set my fuel pressure at on the regulater
what a mess is offline
post #2 of 9 (permalink) Old 05-25-2012, 11:01 PM
matt
mgeistman's Avatar
Re: fuel pressure question
65+- is where I keep mine
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #3 of 9 (permalink) Old 05-25-2012, 11:26 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Yep that is where I keep mine too.
Nate
windrunner408 is offline
post #4 of 9 (permalink) Old 05-26-2012, 01:55 AM Thread Starter
ok thank you much i have mine set on 65 but i wasnt 100% sure i have stock injectors atm should i leave it there or bump it up and would that affect gas milage? cause i went from 15-10 =(
post #5 of 9 (permalink) Old 05-26-2012, 02:03 AM
You mean your fuel mileage dropped by 5 mpg from installing JUST a RR kit!!!????
I would say you most likely have a fuel leak if that is the only mod you did and then noticed a drop in mileage.
Nate
post #6 of 9 (permalink) Old 05-26-2012, 02:10 PM
'05 Excursion
Term3's Avatar
Is this hand calculated or off the milage display?
Term3 is offline
post #7 of 9 (permalink) Old 05-26-2012, 03:56 PM Thread Starter
no it droped a little after i started having hot start issues once we pulled the cab off and replaced stc fitting stand pipes dummy plugs added a powermax and intake manifold once i got it on the street again im getting 250 miles outa a tank of fuel
post #8 of 9 (permalink) Old 05-26-2012, 04:09 PM
Are you still having starting issues?? I would put the truck on stock and check what sort of ICP you are getting. You could have a bad HPOP, ICP sensor, and/or IPR valve.
Nate
post #9 of 9 (permalink) Old 05-26-2012, 04:13 PM Thread Starter
no more hot start issues now u want me to put the program back to stock ?? and i replaced one of those the one on the valve cover on passanger side what else might be wrong then the hpop or icp can those be check with a scan tool or how abouts to i do that? thank you much
