Coolant recirulation kit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-18-2012, 08:36 PM Thread Starter
Anybody running the ats coolant kit? It worth the money and is it needed? Thanks for the info in advance
2004 ford f-250
S&b cai, powermaxx, cfm, arps, mbrp, innovative, 6.4 banjos, blue spring, sinister delete kit, sinister coolant filter, 58v ficm, spearco intercooler, cts.
soon to come s472 and everything to support
04_stroke is offline
post #2 of 10 (permalink) Old 05-19-2012, 12:43 PM
Re: Coolant recirulation kit
I'm bout to put one on my truck. I think anything That helps is worth it
2006 F250 with 35x13.50 18 MTZ'S, S&B intake, Sinister egr delete, banks CAC tube with intake, blue spring upgrade, high idle switch, ccv mod, fp gauge, cat/muffler delete, 6" rough country lift, SCT tuned by RCD, RCD 155/30% injectors, Airdog 100. 9.18 1/8th mile.
Joshbaker is offline
post #3 of 10 (permalink) Old 05-19-2012, 02:30 PM
What does there kit cost
patrickke is offline
post #4 of 10 (permalink) Old 05-19-2012, 04:04 PM
'05 Excursion
Term3's Avatar
It's not that expensive but you need the heads off to drill and tap the holes.
File Type: jpg ImageUploadedByAutoguide1337443405.762134.jpg (224.6 KB, 60 views)
File Type: jpg ImageUploadedByAutoguide1337443437.050020.jpg (203.7 KB, 60 views)
Term3 is offline
post #5 of 10 (permalink) Old 05-19-2012, 04:33 PM Thread Starter
157.11 on thoughbred diesel. If you gotta do all that I'll wait until I stud it then
2004 ford f-250
post #6 of 10 (permalink) Old 05-21-2012, 02:23 PM
nitrogen's Avatar
school me on this , what does it do, and what is the supposed benefit
nitrogen is offline
post #7 of 10 (permalink) Old 05-21-2012, 05:34 PM
Angel Automotive has their own for 150
post #8 of 10 (permalink) Old 05-23-2012, 10:18 AM
'05 Excursion
Term3's Avatar
The back of the heads area that is tapped into has a low circulation rate which means hot spots and poor heat transfer.
Term3 is offline
post #9 of 10 (permalink) Old 05-23-2012, 10:52 AM
nitrogen's Avatar
Can't see any real benefit unless you are making way more power than stock and you intend to operate at high power levels for extended time periods. Just haven't heard of any engine failures attributed to this. While the poor circulation is probably true I don't see it as being bad enough to address. The newer style front cover and waterpump would most likely do more for coolant flow. Especially with an improved pump. I think BD or someone is making a billet one that can't come loose on the shaft
nitrogen is offline
post #10 of 10 (permalink) Old 05-25-2012, 08:45 AM
Yes there is a billet water pump. Bullet proof your diesel makes it. And maybe this isn't something most guys run but for me it's more of a piece of mind thing. Once my build is done I'll have a billet water pump, coolant recerculation kit, coolant filter kit and a bunch of other doodads. If you care look at my tow rig build thread. I figure it like this. It's a known problem and I'm going to do just about everything I can to have a nice running happy 6.0l.
