05 6.0 dyno!! HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 05-17-2012, 01:37 AM Thread Starter
siksix0
05 6.0 dyno!! HELP
you guys getting 4 450 on the dyno on stock injectors and turbo help me out i have the mods listed below except for the ficm tuner...i put it on the dyno the other day at my buddys shop it made 343hp/660 ftlbs trq?? (disappointment)
05 six0 cc shortbed lariat FX4, harley headlights,recon cab lights, egr/oil cooler delete, sct x3(gear head custom tunes), 03 turbo with batmowheel, arp studs, airaid intake, zoodad mod, straight duals w/ 6" tips, php tuned ficm, six4 banjos and blue spring fpr kit
415rwhp/750 ft lbs trq (loaded mustang dyno)
05bbn is offline
post #2 of 28 (permalink) Old 05-17-2012, 01:38 AM
matt
mgeistman's Avatar
Re: 05 6.0 dyno!! HELP
what kind of dyno is it?
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #3 of 28 (permalink) Old 05-17-2012, 01:43 AM
matt
mgeistman's Avatar
i got on a dyno once and the guy said i was making 350rwhp and i had a pmax and studs extreme race tune and nitrous. found out the belts in the dyno were slipping and wasnt reading right or loading up. prolly a pos dyno. jmo
post #4 of 28 (permalink) Old 05-17-2012, 01:44 AM Thread Starter
siksix0
no exactly sure its the real deal tho its a 3000 lb wheel and all that good stuff
05bbn is offline
post #5 of 28 (permalink) Old 05-17-2012, 01:45 AM Thread Starter
siksix0
na they have mustangs and stuff they built there making 7 8 hundred hp consistent.. they also do alot of diesel stuff just not sure why i only made 343 hp i was expevting around 400 rwhp
05bbn is offline
post #6 of 28 (permalink) Old 05-17-2012, 01:54 AM
matt
mgeistman's Avatar
mmmmm in that case idk bro? the only thing i can think of is maybe your turbo vanes arnt comming open all the way? what kind of numbers are you showing on boost and egt?
post #7 of 28 (permalink) Old 05-17-2012, 02:05 AM Thread Starter
siksix0
egt not real sure i know my 05 turbo was showing right at 30 psi on the edge gauge and factory gauge
05bbn is offline
post #8 of 28 (permalink) Old 05-17-2012, 02:06 AM Thread Starter
siksix0
it suppose to only be 23 24 psi but it hit the boost alert on the edge and then on the factory gauge the second and third time it was on 30 psi
05bbn is offline
post #9 of 28 (permalink) Old 05-17-2012, 02:08 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
What tune are you running??
Nate
windrunner408 is offline
post #10 of 28 (permalink) Old 05-17-2012, 02:12 AM Thread Starter
siksix0
sct canned extreme race... my buddy with the same setup basically run his right after mine he made 362/766 with erics tune from id.. but i added the ficm hercules tune from php yesterday so its prob lil better now
05bbn is offline
