Boost numbers - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-16-2012, 07:02 PM Thread Starter
tatertot
Boost numbers
Hey guys was wondering have 03 f250 at 70 mph and 2000 Ron's flat driving I only see about 5 psi for boost is that right
tatertot is offline
post #2 of 13 (permalink) Old 05-16-2012, 07:22 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: Boost numbers
Not sure what "2000 Ron's flat driving" is but 5psi of boost for 70 mph on flat ground is plenty reasonable. Hope this helps.
Nate
windrunner408 is offline
post #3 of 13 (permalink) Old 05-17-2012, 12:08 AM Thread Starter
tatertot
Re: Boost numbers
thanks sorry for the typo meant 2000 rpms
tatertot is offline
post #4 of 13 (permalink) Old 05-17-2012, 12:11 AM Thread Starter
tatertot
Re: Boost numbers
also I was wondering under same condition i'm see 190 degrees on the coolant and 150 on the trans wondering if those were good numbers also just trying to get a good baseline for troubleshooting later on
tatertot is offline
post #5 of 13 (permalink) Old 05-17-2012, 12:26 AM
06kingranch37's Avatar
Re: Boost numbers
That's how my truck runs on the highway so I am thinking ur all set you should check your oil and coolant temps and see how far apart they are
06kingranch37 is offline
post #6 of 13 (permalink) Old 05-17-2012, 12:29 AM
Re: Boost numbers
Yep everything looks kosure to me.
Nate
post #7 of 13 (permalink) Old 05-17-2012, 02:54 AM
Re: Boost numbers
If your ECT is running 190* what is the EOT running to get your baseline readings should be around 198-200* or lower
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
post #8 of 13 (permalink) Old 05-17-2012, 02:56 AM Thread Starter
tatertot
Re: Boost numbers
i'll check it towmorrow putting the gauges in tonite man its a pain but well worth it to see what it is all doing thanks guys
tatertot is offline
post #9 of 13 (permalink) Old 05-17-2012, 04:10 AM
My boost varies but never goes past 33psi
devster55 is offline
post #10 of 13 (permalink) Old 05-17-2012, 04:45 AM
matt
mgeistman's Avatar
Re: Boost numbers
Mine does! Hehe sorry had to
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
