35 inch tire clearance question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 11-09-2011, 02:13 AM Thread Starter
6.0 strokin
power strokin's Avatar
Can my 2003 f250 clear 35's with a leveling kit? What about stock suspension will it clear 35's without a leveling kit?
2004.5 cc sb f250 5" MBRP exhaust, egr delete, afe cold air intake, rerouted ccv, blue spring upgrade, and custom tunes from innovative
power strokin is offline
post #2 of 18 (permalink) Old 11-09-2011, 02:16 AM
Re: 35 inch tire clearance question
my uncle clears 315's with a leveling kit but they scrub the leaves when turned all the way. and from what ive read 315's are pretty much 35's. if im wrong someone please correct me.
05 cc sb 2 inch lift with 315/70r17 hankook dynapro a/t, zoodad, auto meter phantom2 boost and fuel press., banjo bolt mod, afe 3.5" dp into 4" no cat, accufab racing intake elbow, edge evolution, garrett powermax, egr delete, sct w/ innovative tunes, with a peterbilt emblem on the grill!!!
05wh250 is offline
post #3 of 18 (permalink) Old 11-09-2011, 02:45 AM
Twan's Avatar
Yes you can, I had 35x12.5 on 16x10 wheels, they would rub very little, the inerfinder needs to be pulled back, you can do that easy. I pulled it back and would only rub if turned just right and hit a bump. Off set will make it rub more.
2006 CCLB 4x4 King Ranch 2"lift 35's, S&B, sct tunes by Innovative, Quick Tricks, Powermax, 6.4 Banjo bolts, coolant filter, edge insight, 4" turbo back.
Twan is offline
post #4 of 18 (permalink) Old 11-09-2011, 03:03 AM Thread Starter
6.0 strokin
Twan was it on stock suspension?
post #5 of 18 (permalink) Old 11-09-2011, 03:18 AM
315.75r16 is a 34.6" tire they will fit If it rubs the fender liner at all ( I had a lift) just warm it with a heat gun wear welding gloves and push it in wherever you need to. This is what I did when I put 37x13.5" on but i have a 5.5" lift
Piscopop is offline
post #6 of 18 (permalink) Old 11-09-2011, 03:19 AM
Twan's Avatar
No, I had a rancho leveling kit, 2-3" it was a 2004. On my 2006 they would fit for a town only with lift, put a 2" on it and they fit nice.
Twan is offline
post #7 of 18 (permalink) Old 11-09-2011, 05:23 AM
stock
wyoradcat's Avatar
mine still rubbs wit a 2.5 leveling kit on my 2003 35-12.5-20i will go to a 4" or a real leveling kit
wyoradcat is offline
post #8 of 18 (permalink) Old 11-09-2011, 11:00 AM
Fox'sFord's Avatar
On leaf spring they will rub, with coil springs they will not rub
06 F250 leveled on 35's, studded, deleted, Innovative, 4" straight pipe, banjos, spring, ccv w/can, elc w/ filter, DVD/sat/nav in dash, kr running boards, bull bar
Fox'sFord is offline
post #9 of 18 (permalink) Old 11-09-2011, 02:07 PM Thread Starter
6.0 strokin
So after seeing this I see I need a suspension lift, but do they rub bad with a leveling kit? I figure I'll save up and do a four inch lift eventually I just don't Wana get the tires and rub them to wear it starts wearing the tire. It's a big expenditure for me
post #10 of 18 (permalink) Old 11-09-2011, 02:20 PM
Twan's Avatar
What wheel are you going with size and back spacing?
On my 04 I pulled the inerfinder in alittle, around town and drit roads they never hit. If I was off road and turned just right they would hit. Mine never hit the springs. If you live near Colorado you can test fit my wheels to see what they will do.
Twan is offline
