which intake manifold? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 11-07-2011, 01:52 AM Thread Starter
forgive me if this a stupid question, but what is the difference in dougs intake and the one from rudy's? or are they pretty much the same thing?
05 cc sb 2 inch lift with 315/70r17 hankook dynapro a/t, zoodad, auto meter phantom2 boost and fuel press., banjo bolt mod, afe 3.5" dp into 4" no cat, accufab racing intake elbow, edge evolution, garrett powermax, egr delete, sct w/ innovative tunes, with a peterbilt emblem on the grill!!!
05wh250 is offline
post #2 of 31 (permalink) Old 11-07-2011, 01:57 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: which intake manifold?
That is actually a very good question because it may not be obvious. I believe the difference is that the one from Rudy's is just a ported stock manifold that has had its ports machined to help with airflow. However the tubes that the manifold bolts go through are still there. Whereas, with doug's intake, he machines the bolt tubes from the manifold as well as the ports and adds a cover to each side to seal the manifold. hope this helps and makes sense.
Nate
windrunner408 is offline
post #3 of 31 (permalink) Old 11-07-2011, 02:24 AM Thread Starter
thanks. it helps alot trying to plan my build for next year and trying to learn as much as possible about what i need to get and where from.
05wh250 is offline
post #4 of 31 (permalink) Old 11-07-2011, 02:30 AM
Yea I would definitely and actually plan to get my manifold from Doug and the reason is because he actually removes the restrictions in the manifold and provides data for his product.
Nate
post #5 of 31 (permalink) Old 11-07-2011, 12:35 PM
Where can you find info on "Rudy's manifold"?
lenzhotrod is offline
post #6 of 31 (permalink) Old 11-07-2011, 01:07 PM
Not sure you can.
Nate
post #7 of 31 (permalink) Old 11-07-2011, 01:32 PM
strokin6L's Avatar
here's rudy's manifold
Ported Intake Manifold
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #8 of 31 (permalink) Old 11-07-2011, 01:37 PM
I think lenzhotrod was referring to info like doug provides for his intake and I dont think Rudy provides that info unless I missed something.
Nate
post #9 of 31 (permalink) Old 11-07-2011, 03:16 PM
Extended Power's Avatar
Doesn't Rudy sell Elite's manifold?
Have a look at Elite's...it looks alot like the Gogo manifold, but the top is welded back on afterwards.
www.elitedieselengineering.com - PortedIntakeManifold
2003 F-350 KingRanch 4x4
Extended Power is offline
post #10 of 31 (permalink) Old 11-07-2011, 03:26 PM
mmmm...beer....
wetnsloppy4x's Avatar
I hadn't seen the Elite manifold yet. Thanks for the link Ivan. It looks like the lids are welded on and you bolt it down through the holes on top? What plugs the holes? Pipe plugs?
One benefit of Doug's intake is having a little more room for twins in the valley. Tough to tell, but Elite's might be the same way.
Scott
06' F-250 Harley Davidson CC SB
Lifted 6", 37" Nitto Mud Grapplers, intake, exhaust, gauges, tunes by Eric, GoGo Stage 1, Power Max, Strictly RR, Ported Uppipes, Swamps 58v FICM w/Atlas 80, 5r by Elite.
04' Excursion
Stock
99' F-250 EC SB
Stockish
wetnsloppy4x is offline
