replace head studs but not gaskets? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 49 (permalink) Old 11-03-2011, 09:28 PM Thread Starter
harley05's Avatar
hey, just wondering if i do a head stud kit before anything goes wrong is it ok to just do the studs? my head gaskets are still good but want to do the studs and wanna see if it is good idea
2005 ford f350 harley davidson
harley05 is offline
post #2 of 49 (permalink) Old 11-03-2011, 09:29 PM
Back in the 6.oh-no
Harley Strokin''s Avatar
Re: replace head studs but not gaskets?
If you pull the heads your gonna have to get new gaskets too.
2005 F250 Harley Davidson 6.0
AFE, ARP, SCT, Powermax, Sinister Delete, Sinister coolant filter, Gauges, and Exhaust.
Harley Strokin' is offline
post #3 of 49 (permalink) Old 11-03-2011, 09:46 PM
07_powerstroke's Avatar
I did mine one at a time without taking the heads off and everything has been good so far. Also just so u know u have to pound in the firewall on the drivers side to get the stud in. and take the heat box and all that out but it wasnt to bad...
07 ford f250
Josh Vandyke
07_powerstroke is offline
post #4 of 49 (permalink) Old 11-03-2011, 10:24 PM
A guy posted on one of the forums I read that he did his head studs one at a time and didn't have to remove the heat box. He put a jack under the engine and removed the motor mount bolts and was able to cock the engine at an angle and get them in. Sounded pretty creative. He didn't mention any problems with the driver side.
SUPERDUTY_WILL is offline
post #5 of 49 (permalink) Old 11-03-2011, 11:37 PM
SamW's Avatar
If you are going thru the trouble to install studs I would just do it the right way and get the heads decked, new gaskets and all that. Otherwise I think you are better off leaving the bolts until the gaskets blow then do it right.
2006 F250 CCSB
6.
SamW is offline
post #6 of 49 (permalink) Old 11-04-2011, 12:00 AM
Ok well whatever than know it all... I did it and i would love to see someone do it with that box in! And for the outside rear bolt i had to cut it to take it out and to put the stud in i had to make a dent...
07 ford f250
Josh Vandyke
post #7 of 49 (permalink) Old 11-04-2011, 12:04 AM
Why if the gaskets are good? Than if it does blow you are only out of you time anyway. I have driven mine for 12,000 miles so far on a race tune like this and i drive the #### out of it and havent had any puking!
07 ford f250
Josh Vandyke
post #8 of 49 (permalink) Old 11-04-2011, 12:17 AM
I like turtles
NE-STROKE's Avatar
Because the reason head gaskets blow are the factory bolts stretch cause along with head surface tweaking with the heat. Just because there not leaking yet does not mean there not a ticking time bomb. Do it right once instead of risking it. Dont get me wrong just studs could last but doing it right then you never need to worry. Almost all shops deck the heads now days.
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #9 of 49 (permalink) Old 11-04-2011, 12:42 AM
FNG
Dave's Avatar
If you do it that way I will guarantee you will be doing it again.
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #10 of 49 (permalink) Old 11-04-2011, 01:38 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
You don't know if your gasket is compromised or not if you willing to risk it go for it. My gaskets poped even with H11s so that tells you something.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
