new to the performance end of the 6.0... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 10-31-2011, 01:50 AM Thread Starter
ok so i got out of a cummins and into a 6.0l. i have done tons of EGR coolers and oil coolers and head gaskets so for upgrades im obviously going to do ARP studs and black onyx gaskets, EGR delete and replace my oil cooler, im already running a sinister coolant filter. my oil pan is the only part of the truck that is rusting so i figured id pull the motor and do everything at once. this truck is my daily driver and will be sled pulling at every local event. im looking for 450-500hp safely. what kind of advice or input do you guys have besides deep pockets?
any and all input is greatly appreciated!!
SIXOHKID is offline
post #2 of 19 (permalink) Old 10-31-2011, 01:52 AM
Young'n
powerstrokeracing's Avatar
Re: new to the performance end of the 6.0...
Do OEM gaskets for sure.
powerstrokeracing is offline
post #3 of 19 (permalink) Old 10-31-2011, 01:55 AM
Sponsor
04stroker's Avatar
Other than what you mentioned:
Fuel system (I prefer airdog)
Injectors (I've been using warrens work very well)
Turbo (powermax should so the job but ideally I like a non Vgt)
Gauges
You can pm me for prices and discuss sizing of turbo and injectors.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #4 of 19 (permalink) Old 10-31-2011, 01:56 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
and get a monitor or gauges or something to monitor the important stuff. You can find all the things to monitor by searching on here the two biggest though are engine oil and coolant temps to watch that delta to see if your oil cooler clogged on you.
Nate
windrunner408 is offline
post #5 of 19 (permalink) Old 10-31-2011, 02:02 AM Thread Starter
thanks, i checked the EOT and ECT on the ford IDS that we ave at work and the temps were within 15degrees of eachother so i threw a sinister coolant filter on their to clean up a bit. it was also about 60 degrees out when i check the temps so they might be a little off.
SIXOHKID is offline
post #6 of 19 (permalink) Old 10-31-2011, 02:06 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
ECT and EOT needs to be checked at op temp @ 60MPH
and no to BO head gaskets... IMO
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #7 of 19 (permalink) Old 10-31-2011, 02:07 AM Thread Starter
what do you guys recommend for a chip?
SIXOHKID is offline
post #8 of 19 (permalink) Old 10-31-2011, 02:08 AM
Strokin6Liters's Avatar
SCT with custom tunes
2008 Crew Cab Short Bed FX4 6 Speed
Spartan/KEM/S&B/Diamond Eye/Southbend/Top Gun Customz/Bilstein/Toyo/XD/N-Fab/DDM/Recon/Kenwood/JL Audio/Flip Hitch
Strokin6Liters is offline
post #9 of 19 (permalink) Old 10-31-2011, 02:09 AM
Sponsor
04stroker's Avatar
SCT with custom tunes.
holdersdiesel.com
post #10 of 19 (permalink) Old 10-31-2011, 02:25 AM Thread Starter
dont do BO head gaskets?
SIXOHKID is offline
