injector nozzles - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 10-28-2011, 03:54 PM Thread Starter
ricg's Avatar
injector nozzles
ok so i ws doing some research about injectors and was wondering if it would be better to go with a 155 or 175 with stock nozzles or keep stock injectors and go bigger nozzles?? and why?? Also what whould be the price difference?
04 f250 fx4 with 03 turbo (whistle), APR head studs, external oil cooler, egr delete,stock 3.5" exhaust with 6" tip, warrens 175cc injectors, xcal 3 with matts SRL+ tune...SOLD..
2008 f250 with Donahoe Racing 4" lift on 35x12.5. H&S Mini Maxx (HOT DAMN), DPF delete
ricg is offline
post #2 of 17 (permalink) Old 10-28-2011, 03:55 PM
strokin6L's Avatar
Re: injector nozzles
what do you do with the truck?
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #3 of 17 (permalink) Old 10-28-2011, 04:11 PM Thread Starter
ricg's Avatar
its just a DD i dont "think" i want to go to xtream with it but i do want be able to put down some good power...
ricg is offline
post #4 of 17 (permalink) Old 10-28-2011, 04:21 PM
strokin6L's Avatar
so you don't tow with it what so ever?
post #5 of 17 (permalink) Old 10-28-2011, 05:36 PM Thread Starter
ricg's Avatar
Maybe a 20ft skiboat during the summer thats all
ricg is offline
post #6 of 17 (permalink) Old 10-28-2011, 05:39 PM
rdunagan's Avatar
depends on who is doing the injectors. if you want power and tow that boat and thats it id say you could go all the way up to 190's if you wanted to. nozzles are the most expensive part. it cost about what it cost to do the bodies so say that doing all your injectors to 175's runs 500 (thats an exageration figure). if you wanted to do say 75% nozzles with that it would cost somewhere around 1100 or so to do the full body and nozzles. personally im going to get 175's with stock nozzles for now and if i want more power then i will put nozzles on later
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me, fusion bumper with rigid led lights
rdunagan is offline
post #7 of 17 (permalink) Old 10-28-2011, 05:55 PM Thread Starter
ricg's Avatar
thats what i was plan on doing from the get go... but i was reading some other forums and wanted to know what yall thought about it...
ricg is offline
post #8 of 17 (permalink) Old 10-28-2011, 06:14 PM
jdgleason's Avatar
If you are going to run a stock charger, I wouldnt go much bigger than 155s or so. I put some 155s in a buddy of mines truck with a stock charger and I was pretty impressed. It had the grunt of a truck with a tow tune in stock form. Smoke cleaned up real well, and the power curve seemed a little smoother. And with a hot tune, the charger could never clean up the fuel. 155's with a different nozzle should be about 40% ish more fuel than a stock injector.
'09 F350
-JD
jdgleason is offline
post #9 of 17 (permalink) Old 10-28-2011, 07:01 PM
rdunagan's Avatar
well if you keep stock nozzles but just do the bodies the stock charger would do good. and if it needed some help you could always get a batmowheel to go with it
rdunagan is offline
post #10 of 17 (permalink) Old 10-28-2011, 09:08 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
I personally hate tearing in to something over and over again, which is kind of what it looks like you plan to do here. I can understand and relate to the high price tag of injectors but IMO, I would figure out what size you need (both body and nozzle), save up and get them, install them, and tune the truck for them and upgrade around them after that like a larger turbo or batmo or whatever. It is easier and cheaper IMO in the long run especially if something breaks. I just know the more times you tear into something the more that can go wrong. Just my $.02
Nate
windrunner408 is offline
