New up pipe or exhaust block off plate? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-26-2011, 07:21 PM Thread Starter
I'm getting ready to do the EGR delete, oil cooler, and STC fitting. My question is should I use the kit with a new up pipe or exhaust block off plate? I don't know the advantages/ disadvantages of either.
2005 F-250 Crew Cab FX4
6.0L Super Duty
4" Exhaust with muffler
CAT delete
EGR delete
SCT Livewire
-Custom tunes from Quick Tricks
AR Aggie is offline
post #2 of 12 (permalink) Old 10-26-2011, 07:33 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: New up pipe or exhaust block off plate?
If you delete the EGR cooler you will need to use the new up-pipe. Otherwise mod your current pipe. Depends on which delete kit you are using.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #3 of 12 (permalink) Old 10-27-2011, 07:45 AM
New up pipe FTW!!
2005 F250 CC SB 4x4
Trusted Performance Stage 2 fuel system; Fabtech 8" lift;
ARP Headstuds; Banks Intercooler and High Ram Elbow; 4" Exhaust; SCT; Isspro Performax guages
keanoknick is offline
post #4 of 12 (permalink) Old 12-28-2011, 10:19 AM
HMM
Can you be more specific? I was looking at the IPR EGR Delete Kit and it had a choice between the two without a great explanation. Little pricey but looks well made. Thanks!
HMM is offline
post #5 of 12 (permalink) Old 12-28-2011, 10:31 AM
Davey B
davey99ps's Avatar
I'm not sure what the benefits are between the 2, but I just got done doing a friends truck an I used the sinister kit which came with a new up-pipe. It came with good instructions, an went together nice. Biggest pita was getting everything apart, reassembly went real easy
95 CCLB- 238/100s, H2E, termy t500, wipe out pushrods, comp 910s, mbrp exhaust, bdp tunes, and 8" lift
99 ex cab - Rolled 3/10/10
davey99ps is offline
post #6 of 12 (permalink) Old 12-28-2011, 11:09 AM
Caterpillar Tech.
06deezel's Avatar
I would get the new up pipe....when i did my egr delete i used the block off plate and i had the exhaust bellow blow on the passanger side, so i ended up have to put the solid up pipe on anyways.
2006 F350 SRW 4X4
SCT Livewire with gearhead tunes
Egr delete
Sinister diesel coolant filter
8k HIDs
4" mbrp
35x12.50x17 nitto trail mt
06deezel is offline
post #7 of 12 (permalink) Old 12-28-2011, 03:09 PM
Use the new up pipe,
I think it is the 05 and up trucks that have a scoop in the stock up pipe that restricts flow.
swaan is offline
post #8 of 12 (permalink) Old 12-28-2011, 03:38 PM
Banned
Smut's Avatar
If you put in a block plate you add a point for possible failure and an interruption in gas flow. Best thing to do is put in a new solid pipe
Smut is offline
post #9 of 12 (permalink) Old 12-29-2011, 12:27 AM
HMM
Thanks all!
HMM is offline
post #10 of 12 (permalink) Old 12-29-2011, 01:33 AM
One way will pass a visual smog inspection and one won't.
lenzhotrod is offline
