fuel issues after mods - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-23-2011, 05:11 PM Thread Starter
trucknut56's Avatar
I just swapped in 6.4 banjo bolts, the upgraded fuel pressure regulator spring kit, fuel filters and cleaned out the egr on a buddies 06 6.0 and now the truck does not run right the engine light is on and the fuel consumption has gone up considerably. The truck also has a K&N cold air kit, exhaust and a predator chip. Anybody got an ideas on what the issue is? There are no fuel leaks
trucknut56 is offline
post #2 of 4 (permalink) Old 10-23-2011, 08:35 PM
injected79's Avatar
Re: fuel issues after mods
do you have a fuel pressure gauge?
Sold puller-1997 f-350 12 valve 913 p-pump, big charger, big fuel, SBC, and so on
Puller-1979 Ford S/B, 60 front, 10.25 rear, 5.13 gears, ockers, 503 BBF, C6 with 2500 stall
DD-2005 F-250 c/c s/b 6.0L lariat, 6" lift, 35"m/t's, 18x12's, 58v ficm, gearhead tuned, 6.4 banjo's, raptor fuel system, 5" exhaust and a CAI
**No Non-sponsor Links**
injected79 is offline
post #3 of 4 (permalink) Old 10-23-2011, 08:45 PM
Boost96's Avatar
If it ran fine prior to mods, double check your work. and def check the fuel psi under load like the guy above said. What code are you tripping?
Boost96 is offline
post #4 of 4 (permalink) Old 10-24-2011, 11:16 PM Thread Starter
trucknut56's Avatar
i rechecked everything today and also checked the codes, there was one code, excessive EGR flow. We will change the egr valve tomorrow and see how it works
