Question about Injector nozzles on 175's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 10-20-2011, 05:22 PM Thread Starter
rdunagan's Avatar
Ok i already know that Warren diesel is going to do my injectors. But i have read a few threads that the elite diesel injector nozzles are a 8 hole shot vs a 6 hole shot. Now with that being said i have also read that people with th 8 hole nozzles are reporting better fuel mileage with them. Also would these result in more power as well? Also another question is, when jess does my injectors which would be better the 8 hole hybrid or the reg 6 hole shot.
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me, fusion bumper with rigid led lights
rdunagan is offline
post #2 of 19 (permalink) Old 10-20-2011, 05:38 PM
i like to party
pizza pig's Avatar
Re: Question about Injector nozzles on 175's
The guys over at MPD also use 8 hole nozzles on certain injectors, not sure but I dont believe 75 and 100 over nozzles are available in 8 hole style. The 8 holes are supposed to give better atomization of the fuel so that probably warrants the better fuel mileage but I honestly have no idea. Hopefully someone chimes in because I'd like to know as well.
pizza pig is offline
post #3 of 19 (permalink) Old 10-21-2011, 12:52 AM Thread Starter
rdunagan's Avatar
well elite uses 8 holes on there big injectors as well. but i think on there 185's they use a 50% honed nozzle
rdunagan is offline
post #4 of 19 (permalink) Old 10-21-2011, 01:56 AM
Sponsor
jwarren's Avatar
I have seen 50% honed nozzles on my nozzle pop off tester leak so honed nozzles can be risky. From what I have seen 8 hole nozzles make no more hp than a 6 hole.
jwarren is offline
post #5 of 19 (permalink) Old 10-21-2011, 02:05 AM
3brorce's Avatar
Heard of better fuel atomization or better fuel mileage?
03 6.0 Full EGR delete, S&B CAI, 4in turbo back, 70hp injectors, Moded Banjos, fuel spring mod, GearHeads, RCD, IDP and TSD tuned, trans temp, boost, egt, fuel press, MIA
08 6.4 4in dp. 5in TBE. S&B, Studs, EGR delete, No limit elbow/CAC pipe, Spartan, TSD, QTP and IDP LW tuned
07 5.9 5in TBE, Goerend, Fass, EFI Anarchy Diesel Tuning
3brorce is offline
post #6 of 19 (permalink) Old 10-21-2011, 02:52 AM Thread Starter
rdunagan's Avatar
i dont want risky. the main reason i was thinkin about it was for the fuel mileage. yall will be doing my injectors just wanna try and get good fuel mileage at the same time
rdunagan is offline
post #7 of 19 (permalink) Old 10-21-2011, 02:58 AM
Sponsor
jwarren's Avatar
8 hole nozzles may get better fuel economy IMO its not going to be a big difference.
jwarren is offline
post #8 of 19 (permalink) Old 10-21-2011, 03:02 AM Thread Starter
rdunagan's Avatar
jess i know about injectors in general but your the injector man! how much better would you think? and elite told me with those nozzles that you have to plug some relief valve or something like that. is this true and what risk does that impose?
rdunagan is offline
post #9 of 19 (permalink) Old 10-21-2011, 04:21 AM
There is a relief port on the injector that lets fuel bypass under light throttle. 155's are usually as simple as plugging that port so that you are getting all the fuel with no bleed off. Any larger and you will have larger barrels and whatnot...
FaSSt9602 is offline
post #10 of 19 (permalink) Old 10-21-2011, 04:57 AM
Redneck6.0L's Avatar
Every elite injector I've seen, we have removed the 8 hole nozzles and put 6 hole either 75,100 or 150% over nozzles on them, hypermax started out using this certain brand and now casserly,industrial,mpd,innovative all use them. I have 205s with 100% nozzles on the tow truck and I average 10-12mpg towing 12 000lbs at an average of 75mph everywhere I go
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
