200cc Injectors and ?????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 86 (permalink) Old 10-16-2011, 07:15 PM Thread Starter
I recently installed 200cc injectors and now i am needing a turbo. I am waiting to get tunes till i get the turbo so what turbo do i get. I was considering a powermax just for the cost and ease of install. I was also looking at a bullseye 64mm turbo, they have two differet version. I tow a mud truck maybe three times a year, and otherwise just a daily driver and weekend play toy. So when i tow i will take it easy. Also considering water meth to lower the egt's and an extra power adder. Just wondering. Also the cheaper the price the better. Thats also why the powermax is taaking the lead. Thanks Guys.
2006
F350, 6.0, CC, SWB, VEGISTROKE, AD2, ARP's, OEM Gaskets, Pmax, 200cc Sticks SCT SF3, FICM Tunning, Custom ZOODAD, Coolant Filter, EGR Delete, Smoked Cab Lights, 6" Mitre Stacks, 8" 4-link Lift, SS-M16 37/13.50/20 SURE WAS NICE WITHOUT THE ADS
YoungMT Hick is offline
post #2 of 86 (permalink) Old 10-16-2011, 07:48 PM
Re: 200cc Injectors and ??????
power max is a good option, I had hypermax 190 cc in my 6.0 and had a stage two vgt then an elite HO, both great turbos. Elites was too big to tow with. I also used water meth and it worked great, but really it is not needed... my buddy runs a power max with 190cc inj and he tows everyday, and it works awesome... just do research and do it right the first time..
05 LLY DMAX, EFI, AIR, FUEL, BUILT TRANS, TRACTION AND MORE!! POWERSTROKE SLEEPER SLAYER
dukcaln1 is offline
post #3 of 86 (permalink) Old 10-16-2011, 07:52 PM
Reppin' the 6.4L
SickStroke6.0's Avatar
That is gonna suck to tow with!!
Blake
Looking for a second 6.4L....
2008 F-250 CCSB King Ranch 6.4L
4" Rough Country Lift, Dual Steering Stabilizers, 20x10" XD Diesels, 35x12.50x20" Mickey Thompson MTZ's, Line-X, 15% Tint, MBRP 4" Cool Duals w/ 6" Tips, S&B Intake, Flo-Pro EGR Delete and Elbow, MBRP CAC Tube
SickStroke6.0 is offline
post #4 of 86 (permalink) Old 10-16-2011, 08:31 PM
WINNING
Countryboy07's Avatar
IMO, I'd go with a 64mm non vgt turbo with a .70 housing on it. It is going to suck towing, but with water/meth, it would be a lot better. When I had my 190's and 62/70 non VGT, it sucked towing my brothers truck down to Texas. Ran about 1,300* the whole way down!
The powermax is a great turbo, but you will run out of air on top quickly unlike you will with the non VGT. Just my opinion.
-French
2002 VW Jetta TDI
Countryboy07 is offline
post #5 of 86 (permalink) Old 10-16-2011, 08:38 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Not sure if it's available or not but if possible get a diverter valve for a 64mm non-VGT turbo. As already mentioned you will get way more air up top than with a powermax. It will cost more than the powermax but IMO should, if set up right, be able to handle the towing duties you would need it for and give some good ponies for the street. Just my $.02
Nate
windrunner408 is offline
post #6 of 86 (permalink) Old 10-16-2011, 09:42 PM
BRING DA AMBALAMPS
stroke of luck's Avatar
for a fun dd toy, the powermax is a perfect match for my 190's (mine were actually flowed a little more than 190.) great spool up and decent temps. could use some air on the top end but it still flows pretty close to a 64. also, I dyno'd 534 / 1211 yesterday with my setup.
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #7 of 86 (permalink) Old 10-16-2011, 09:43 PM
07strokerftw's Avatar
I wouldn't go powermax with anything over 190s, but for towing purposes the VGT will help. If you tow though, the best option overall would be a set of twins IMO
Just for starters though, what's the heaviest you would be towing and how far? on average
2007 F250 ccsb Lariat
33" Nitto Terra Grapplers on stocks, SCT x3 with custom extreme tunes from IDP, Autometer gauges, zoodad air mod, "2003" turbo, carriage works billet grill layover, HID 6000k, headstuds/egr delete, 6.4 banjo fuel bolt upgrade, 4" turbo back to 7" single stack
07strokerftw is offline
post #8 of 86 (permalink) Old 10-16-2011, 11:18 PM Thread Starter
Thats kinda the power i was looking for. Ya i would like the powermax for the cost. and even if i get it and run it for a while then it comes time for an upgrade it seems like the powermax has a good resell value.
As for towing I tow a 1974 f150, regular cab long bed, trailer is only rated for 7k maybe anywhere from 50-150 miles. then maybe once in 4-5 years i will go cross country with that to move for the navy. and thats probably what it is at. So i dont tow that much anyways.
EGT probe should get here tomorrow hopefully and install it then see what egts are with stock turbo. If i can get a 64mm non vgt with a t3 housing so i can get the diverter valve for later that would be good. probably the best situation but i am working around the 1k value range maybe up to 1500 for the right turbo. Thanks for all the input though.
Wife says I dont care what it cost, just clean up the black smoke
2006
post #9 of 86 (permalink) Old 10-16-2011, 11:43 PM
i like to party
pizza pig's Avatar
well a 64mm with diverter valve is going to run you over 2k easy. The BD valve alone is 700
pizza pig is offline
post #10 of 86 (permalink) Old 10-17-2011, 12:13 AM Thread Starter
Ya that's why I am hoping to get a 64mm non vgt then get a diverted valve later. As money come s in
2006
