Time to start the build - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 10-15-2011, 03:11 PM Thread Starter
justintimemoto's Avatar
Im going to be doing this a little at a time. When the cab is off i am going to do head studs the master solution kit from mkm customs although i have a egr delete kit all ready so i will see if they can keep that and the black onyx head gaskets. From what i read the oem ford ones are better now And get the heads checked. Also while The cab is off i want to do dozer diesel regulated return. How many people have heard of him or run his return? That's what i plan to do while the cab is off. The next thing i want to do is the tranny is it better off i buy all the pieces and let the tranny guy be me build it? what do i need if i do that? or would i be better off getting it from nadp or suncaost im open to suggestions. Also once i save up again i want to do injectors from warren diesel probably 175s since i pull trailers and a 64mm non vgt turbo from river city diesel and custom tunes from innovative and eventually a tuned 58v ficm from swamps. like i said this will take a while since im not rich. If anyone would like to make a suggestion im open to them and any help thanks!!!!!!
sucperchips flashpaq, banks ram air, 4"mbrp straight piped rcd egr delete leveled
justintimemoto is offline
post #2 of 23 (permalink) Old 10-15-2011, 03:17 PM
Sponsor
04stroker's Avatar
Re: Time to start the build
I'd let someone such ad napd or suncoast that's familiar with the 5r110 do the build. Cost a little more but worth it IMO. Everything else seems ok be careful when choosing housing and exhaust wheel for that turbo so it's tow friendly and not laggy. Some other cheap insurance would be a coolant filter. If you would like pm me and I can get you some prices on Warren injectors. I run them in my truck and love them. Also I can help set you up with right size injector for your needs.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #3 of 23 (permalink) Old 10-15-2011, 03:40 PM
Redneck6.0L's Avatar
Rcd 64 is too big if you tow eavy and lots. When will people fugure this out. If you have to tow at 55-65mph or around 1800rpm in overdrive. You'll hate that charger. Don't care where you buy it but 62/65/70 is the largest some 155-165 with 75% nozzles. Nadp trans all the way
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
post #4 of 23 (permalink) Old 10-15-2011, 03:50 PM
strokin6L's Avatar
agree with shawn on the turbo. The 64mm will be too big if you tow especially haveing a big exhaust wheel on it. If you really want a non vgt turbo do like he said or go with the powermax.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #5 of 23 (permalink) Old 10-15-2011, 07:19 PM
SUPERIOR OFFROAD INC.'s Avatar
NADP Trans all the way, you will not regret that choice, Powermax IMO is the best middle of the road turbo for all-around usage.
2011 6.7 yet to be ####ed with.... Yet...
SUPERIOR OFFROAD INC. is offline
post #6 of 23 (permalink) Old 10-15-2011, 07:31 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
It drops right in and if you go with larger injectors you can add a batmowheel if necessary to help lower EGTs if you need it.
Nate
windrunner408 is offline
post #7 of 23 (permalink) Old 10-15-2011, 08:39 PM Thread Starter
ok thanks for all the imput, Where have yall gotten your studs from as a kit and what did you pay for it? the one im looking at is like 1600 to much?Complete Solution(TM) for Ford 6.0L Powerstroke with Sinister EGR Delete Kit, Oil Cooler, ARP Studs and SCT X3
also i want to see if they will swap the black onyx out with ford oem and see if they will take the egr delete out since i all ready have one, and it comes w 3free tunes how are mkm customs tunes? also how many tunes can a x3 hold?
post #8 of 23 (permalink) Old 10-15-2011, 08:42 PM Thread Starter
or would i be better off with this kit? MKM Complete Master Solution Kit for 6.0L Powerstroke (Sinister EGR Delete, ARP Studs, Gaskets, Oil Cooler)
post #9 of 23 (permalink) Old 10-15-2011, 10:00 PM
Factory ford gaskets
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
post #10 of 23 (permalink) Old 10-15-2011, 10:15 PM
Sponsor
04stroker's Avatar
Deff what Shawn said on the gaskets.
holdersdiesel.com
