Sinister coolant filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-12-2011, 04:22 PM Thread Starter
mcdaniel1991's Avatar
Every since I installed the coolant filter my truck leaks coolant If I turn the valves off it stops leaking I can't pinpoint where it's coming from ether just wondering if anyone has had this problem
mcdaniel1991 is offline
post #2 of 7 (permalink) Old 10-12-2011, 05:16 PM
Stroke it B!tch
fordboy11's Avatar
Re: Sinister coolant filter
Yea did you wrap the bolt with the lock tight paper? I forgot on one bolt and it leaked but after I wrapped it up I was good to go. Good luck.
78 F-150 300 straight 6, 3 on the tree
03 F-250 6.0 Play toy
06 F-250 6.0 (general nightmare) 2.5 pulling truck
12 F-350 6.7 Tow rig
Gotta pay to play son!
Originally Posted by F-250-Owner View Post
I know you said you wouldnt turn it up..... but come on.... its like saying "I promise I will only stick the tip in" never happens like that
fordboy11 is offline
post #3 of 7 (permalink) Old 10-12-2011, 05:29 PM Thread Starter
I just followed the instructions and it didn't say anything about ( wrapping ?) a bolt in loc tight ( paper?)
post #4 of 7 (permalink) Old 10-12-2011, 05:30 PM
3brorce's Avatar
He means you need to put teflon tape on the fittings
03 6.0 Full EGR delete, S&B CAI, 4in turbo back, 70hp injectors, Moded Banjos, fuel spring mod, GearHeads, RCD, IDP and TSD tuned, trans temp, boost, egt, fuel press, MIA
08 6.4 4in dp. 5in TBE. S&B, Studs, EGR delete, No limit elbow/CAC pipe, Spartan, TSD, QTP and IDP LW tuned
07 5.9 5in TBE, Goerend, Fass, EFI Anarchy Diesel Tuning
3brorce is offline
post #5 of 7 (permalink) Old 10-12-2011, 05:31 PM
powerstrokedkid87's Avatar
take the fittings out where the lines run into the filter housing and wrap them with Teflon Tape ( im assuming thats what he means by lock tight paper) that should help you out. I had a similar issue. Little teflon tape on the fittings, tighten her down...good to go
completley stock truck...just a simple cat back system....and maybe a few other odds and ends
powerstrokedkid87 is offline
post #6 of 7 (permalink) Old 10-12-2011, 05:36 PM Thread Starter
Ok that makes more sense I'll try that and see what happens
post #7 of 7 (permalink) Old 10-13-2011, 04:52 AM
Stroke it B!tch
fordboy11's Avatar
Haha yea sorry I had a huge brain fart. Teflon tape. It should do the trick.
