Oil Cooler Delete Kit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 10-12-2011, 01:20 AM Thread Starter
I Love Work'N On Hot Rods
windrunner408's Avatar
This is what I came up with as an alternative for the BPD kit. Now I am definitely not saying that the BPD kit is in any way junk or sub standard in any way and only time and towing will tell how my kit holds up. I was however able to make this kit for about $300 less than the BPD kit but at the expense of extra time fabricating and figuring. There were two reasons I went this route. One I didn't like how much the BPD kit cost and two I really wanted to have a bypass filter in addition to my full flow one. (I know that the BPD has one but I just liked how the Amsoil had it built in with the full flow one.) I actually used an oil filter relocation kit for a 7.3L (that is what Amsoil had it for) so I used the full flow filter recommended for that motor (it is an Eao26 filter and is roughly the same size as the 6.0 cartridge filter if not bigger) and I used an EaBP110 bypass filter. This is actually a revision of my original kit. Originally I had used a B&M transmission cooler instead of the fluidyne one I have now. It was about the same size but half as thick and ony had 1/2in lines feeding in. The Fluidyne one (which is the same brand of cooler as the BPD cooler) has 12AN (3/4in) ports on it and is massive. I also added a thermostat to the mix as it would take forever for my oil to heat up. The thermostat is a Canton racing thermostat that is all aluminum construction with stainless steel bolts, has 12an ports, and opens at 215F. All of the brackets are aluminum with stainless steel hardware (except the one that holds the filters which is steel because the aluminum flexes too much). I also used aluminum an fittings on the push lock hose. Now of course I did use the BPD oil manifold block. It is made of aluminum and is a piece of work. It is expensive but is the best way to delete the oil cooler in my opinion and has 12an ports as well. All of the lines are 12an. I tried to stick with aluminum and stainless steel to keep everything from rusting as what happened on my first kit and is what I would assume would happend with the BPD kit unless you painted everything. Like I said up top, I am not in anyway knocking the BPD kit as I think it is a very high quality kit. It just wasnt for me and I thought I could make something that better suited my needs and wanted to share my ideas with other DIYers/Fabricators out there. Hope this helps.
Nate
windrunner408 is offline
post #2 of 34 (permalink) Old 10-12-2011, 01:27 AM
NSTY 6OH
Dangyo's Avatar
Re: Oil Cooler Delete Kit
nice work. looks great
2006 FORD F-250 FX4 6.O REGULAR CAB
Built motor/studded/fuel system/tons of bolt ons/exterior mods/lots of gauges/bottle fed/etc
Tuned by Matt Robinson of Gearhead Automotive Performance
Dangyo is offline
post #3 of 34 (permalink) Old 10-12-2011, 01:32 AM Thread Starter
Thanks man.
Nate
post #4 of 34 (permalink) Old 10-12-2011, 01:45 AM
'05 Excursion
Term3's Avatar
Looks great?? Are you kidding me?? It looks FANTASTIC!!!!
Term3 is offline
post #5 of 34 (permalink) Old 10-12-2011, 01:50 AM
Stroke it B!tch
fordboy11's Avatar
Wow dam good job haha maybe you could start making some for us
78 F-150 300 straight 6, 3 on the tree
03 F-250 6.0 Play toy
06 F-250 6.0 (general nightmare) 2.5 pulling truck
12 F-350 6.7 Tow rig
Gotta pay to play son!
Originally Posted by F-250-Owner View Post
I know you said you wouldnt turn it up..... but come on.... its like saying "I promise I will only stick the tip in" never happens like that
fordboy11 is offline
post #6 of 34 (permalink) Old 10-12-2011, 01:58 AM
Arctic Fox's Avatar
The oil cooler you used looks to be bigger than the one used by BPD? And I like your mounting position better.
With the thermostat opening at 215 what oil temps are you seeing when towing?
2006 F-450 XLT 4x4 6.0 Auto 4.30L
Kelderman 4-Link Airbags, Lariat Seats, 2011 Mirrors
CTS, SCT, ARP's & oem Gaskets, BPD 6ph FICM
Spearco IC, Ported Intake, Powermax, 4" Exhaust
BPD Oil Cooler, Oil By-Pass Filter
46,000 miles
Arctic Fox is offline
post #7 of 34 (permalink) Old 10-12-2011, 02:12 AM Thread Starter
Well as I havent had the kit on long at all yet, what I have seen from initial cruising at hwy speeds at say 70 mph or so is oil temps get up to 205-210F with ambient temp of 75F. Now keep in mind that this is still below the opening set point of the thermostat (215F) but it is with the thermostat sending just a portion (i.e. 10%) of the flow to the cooler to keep it warm while the oil heats up. According to fluidyne this cooler can remove 30000btu/hr with just 5mph of wind and it goes up to like 90000btu/hr when air speed gets like 40mph or so. My B&M cooler I had on before was only rated to like 28500Btu/hr, had a fan on it, was mounted on the frame rail, and in 85-90F heat would get the oil temp up in the 220s towing a 10-12K load. I presume that oil temps will probably be in the 220F neighborhood +/-5F. The basis for the oil thermostat opening at 215F is to get the oil hot enough to vaporize moisture from condensation in the oil. You dont get that very much when oil temps are in the 180-200F range IMO. Time will tell how well it works with towing. I dont tow very regularly but would love to test it out. Hope this helps.
Nate
post #8 of 34 (permalink) Old 10-12-2011, 02:20 AM Thread Starter
[QUOTE=Arctic Fox;1665667]The oil cooler you used looks to be bigger than the one used by BPD? And I like your mounting position better.[QUOTE]
I thought it was bigger as well. I couldnt ever figure out what size theirs was so I decided to go bigger just to be safe.
I mounted it with about an inch and a half away from the condenser to minimize heat transfer from the oil cooler to the condenser and the oil cooler definitely flows air through it very well. The air flow also helps cool the thermostat.
Nate
post #9 of 34 (permalink) Old 10-12-2011, 11:08 PM
It wasn't me
offroadinginaz's Avatar
That was a lot of work and engineering. Nice work! How does your A/C function with the added heat load on the condensor?
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #10 of 34 (permalink) Old 10-14-2011, 03:14 AM Thread Starter
Ok well so far after three days and over 130 miles, so far everything seems to be working good. I dont have a trailer to tow but with temps today at about 80F and speeds in excess of 80 mph (mostly between 70 and 80 for over a ten mile stretch) oil temps still have never exceeded 209F and for the most part flucuate between 203F and 208F. A/C seems to be keeping my cab cool just fine. (I know its not the sweltering heat we were having this summer but I still have to use the A/C.
Nate
