pause between shifts after tuning - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-04-2011, 02:21 AM Thread Starter
Well Hung Member
stroked's Avatar
i never really thought twice about it, and the time that the pedal spends on or close to the floor is minimal anyways. After i installed the srl tune from matt on the truck, seems that when i mat the pedal it takes an extended time between shifts, but when it does it shifts quick and firm. not a slipping, and doesnt seem like a trans issue, just maybe a tcm issue? anyone else have this with the srl tune?
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #2 of 12 (permalink) Old 10-04-2011, 02:26 AM
Waitin' on 500
Choupique108's Avatar
Re: pause between shifts after tuning
Mine does the same on my 7.3... when i asked matt he said something along the lines of the tune makes the truck defuel so it doesnt harm the trans. Ive had his tunes for just about 2 yrs and still on stock tranny. Nothing has been done to it except an oil change.
1997
Single Cab Dually
S366 w/Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s,
Corbeau seats w 08 console, 19.5s, Black Interior with swede headliner and visors,
Custom badges, Flight Fab/DIY traction bars.
2012 CCSB F250 Ultimate Lariat.
Choupique108 is offline
post #3 of 12 (permalink) Old 10-04-2011, 02:49 AM
i like to party
pizza pig's Avatar
its the solenoids in the trans getting weak... dont know why matts tunes seem like they're the only tunes that make it apparent.
I get a nice flare on the 3-5 shift
pizza pig is offline
post #4 of 12 (permalink) Old 10-04-2011, 02:57 AM
Mine is doing it also...have you done anything to fix it?
2007 F250 CC Lariat
Black Onyx Head Gaskets (1st time)
Studded and trans built by BTS
Sinister EGR Delete & Coolant filter
Powermax Turbo
Edge insight CS W/Pyro & Fuel Pressure
MBRP 4" Straight pipe
423RWHP 753RWTQ
sly1types is offline
post #5 of 12 (permalink) Old 10-04-2011, 02:59 AM
RazorsEDGE's Avatar
I have not noticed this with my SRL tune. It shifts quick and firm, of course I came from a Banks 6 gun to Matt's tune so maybe I just don't notice.
2005 F250 4x4 King Ranch 6.0
Two tone removed, Quad Captains, High idle mod
Edge Insight CS w/ EGT and fuel PSI, Dieselsite coolant filter
Pace Edwards Electric Bedlocker with Bedrug
Tuned by [email protected]
RazorsEDGE is offline
post #6 of 12 (permalink) Old 10-04-2011, 03:08 AM Thread Starter
Well Hung Member
stroked's Avatar
oh, youd notice, it takes a while between shifts, but if i bring the pedal just a little bit off the floor it seems like it breaks the tires loose easily shifting gears. i was thinking maybe a hole in the tuning,
Donnie
stroked is offline
post #7 of 12 (permalink) Old 10-04-2011, 03:22 AM
i like to party
pizza pig's Avatar
you need to replace you direct shift solenoid in the trans with the gogo diesel solenoid... its an OEM one modified on a solenoid tester that flows 4 times the fluid of the stocker...
over time all of the solenoids wear out so some trucks may be different than others.. only my 3-5 shift has a flare where is some may see a 1-2 or 2-3 flare (these are different solenoids)
post #8 of 12 (permalink) Old 10-04-2011, 03:24 AM Thread Starter
Well Hung Member
stroked's Avatar
well since its every shift, maybe ill ask matt if there is a defueling in the tuning, for trans life. before i go buy 2 solenoids
Donnie
stroked is offline
post #9 of 12 (permalink) Old 10-04-2011, 04:03 AM
i like to party
pizza pig's Avatar
im not saying thats your issue, call him and work with him, maybe the file got messed up
post #10 of 12 (permalink) Old 10-05-2011, 12:40 AM Thread Starter
Well Hung Member
stroked's Avatar
matt expressed concern about a possible fuel pressure issue, going to look into it a little further, see if i can get it in the pids on the ids and monitor it there, im not going to install a fuel pressure gauge on an otherwise stock truck.
Donnie
stroked is offline
