SCT on Multiple Vehicles - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-30-2011, 06:32 PM Thread Starter
This Gets Addicting
ScottF4444's Avatar
Got a new Mustang. Can I use the same SCT X3 I use on my 6.0l and tune the Mustang? SCT part number is the same, just didn't know if I could float the same tuner between vehicles????? Thanks!
ScottF4444 is offline
post #2 of 16 (permalink) Old 09-30-2011, 06:50 PM
FNG
Dave's Avatar
Re: SCT on Multiple Vehicles
Cant without returning one to stock and unlocking it every time. After every five times it would cost you 150
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #3 of 16 (permalink) Old 09-30-2011, 07:22 PM
Busted Nuckles
I have an SCT SF3 (3015). I've been using only the canned tunes and it still says 'unmarried' and 5 unlocks left.
OK, so my tuner is single. But I thought that once you used the tuner on a vehicle it would become married to that vehicle. What is it that constitutes a marriage in the SCT culture.
I haven't loaded a custom tune, yet....is that what ties the knot?
bustednuckles is offline
post #4 of 16 (permalink) Old 09-30-2011, 07:31 PM
<--won't start
Constantfix's Avatar
Would you have to return it to stock? could you load a tune on one, leave the tune on. Back up the stock file on a computer, then switch to the other vehicle and repeat the process?
Constantfix is offline
post #5 of 16 (permalink) Old 09-30-2011, 09:11 PM
FNG
Dave's Avatar
cant do that.
Dave G
Dave is offline
post #6 of 16 (permalink) Old 09-30-2011, 09:34 PM Thread Starter
This Gets Addicting
ScottF4444's Avatar
Thanks for the info Dave.
post #7 of 16 (permalink) Old 09-30-2011, 10:42 PM
strokin6L's Avatar
It becomes VIN locked to that particular vehicle. You can return that vehicle back to stock and tune another vehicle tho...and then that vehicle will become VIN locked. But everytime to go and turn a vehicle back to stock and tune another vehicle with the same SCT device...you will lose a unlock on it. You can only do this 5 times like already mentioned. Once those 5 unlocks are used up you will not be able to use the SCT again until you send it to SCT and have them add more unlocks to it. You're just better off getting a SCT for each vehicle...that way each vehicle has it's own SCT with it's own custom tunes on it.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #8 of 16 (permalink) Old 10-01-2011, 03:44 AM
Busted Nuckles
Thanks, strokin6L,
Do I lose an unlock if I return the vehicle to stock and then load another tune to the same vehicle?
Every couple years I need to take it in to get it emissions tested.
post #9 of 16 (permalink) Old 10-01-2011, 01:17 PM
strokin6L's Avatar
Thanks, strokin6L,
no you will not lose an unlock cause the device is VIN locked to that vehicle. You only lose an unlock when you tune another vehicle. You can turn it back to stock as many times as you wish.
post #10 of 16 (permalink) Old 10-01-2011, 05:17 PM
lubeowner's Avatar
You could go out and buy the Ford IDS setup for somewhere in the neighborhood of $5000 or more. Then you could change the flash and vin numbers of each truck to be the same in the computers. At least you could say that you only had one tuner. Now if you had lets say 20 trucks or more that are similar then it may pay off to buy the ids. That is if you can figure out how to change the vin numbers with it. So really in the end you need to buy another SCT it is really cheap once you factor everything in. Oh and since we are talking about a mustang and a Superduty you don't really have the ids option.
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
