Egr valve turned off? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-29-2011, 03:33 PM Thread Starter
southbend_powerstroke's Avatar
So I was having problems with to much boost and my uncle (master mechanic from ford) suggested I used my sct programmer to turn it off. With out a delete will this effect my truck in a negative way?
southbend_powerstroke is offline
post #2 of 12 (permalink) Old 09-29-2011, 03:37 PM
BCPSD's Avatar
Re: Egr valve turned off?
No negative effects. You'll need someone to write a tune to turn it off. I've ran mine off for several years.
06 6.0 Powerstroke Crew Cab
S&B Intake
MBRP exhaust
Powermax
TSD tunes
BCPSD is offline
post #3 of 12 (permalink) Old 09-29-2011, 03:38 PM
FNG
Dave's Avatar
Do you have custom SCT tunes? If so its already off
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #4 of 12 (permalink) Old 09-29-2011, 03:44 PM
Administrator
Zmann's Avatar
SCT canned tunes have a provision for no EGR now SCT Performance - More Power! Less Fuel!
but I don't see how this is contributing to an overboost situation ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 12 (permalink) Old 09-29-2011, 03:53 PM
BCPSD's Avatar
Not necesarily, tuners have always asked if I want it on or off.
S&B Intake
MBRP exhaust
Powermax
TSD tunes
BCPSD is offline
post #6 of 12 (permalink) Old 09-29-2011, 04:12 PM
'05 Excursion
Term3's Avatar
Just to clarify, it turns off the EGR valve and eliminates the codes you would get. It still does not take care of the fan clutch issue if you unplug the EGR valve and toss it in the trash. Wish they would fix this issue.
Term3 is offline
post #7 of 12 (permalink) Old 09-29-2011, 04:39 PM
Administrator
Zmann's Avatar
I actually don't have the fan issue unplugged but I don't have the very latest flash I have the one before it
no tunes custom or canned fix the fan issues IIRC so I didn't bother mentioning it
you just leave it plugged in and zip tie it out of the way to keep the ECM and fan happy as you know
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 12 (permalink) Old 09-30-2011, 02:17 AM
Sorry for my ignorance but what is the "fan issue"?
lenzhotrod is offline
post #9 of 12 (permalink) Old 09-30-2011, 05:13 AM Thread Starter
I can't say that the whole over boost thing is correct by any means becuz I did explain the issue over the phone lol. But anyways I just wanted to check with unguys before I go across the mountains and something goes wrong. Thanx for the help guys!
post #10 of 12 (permalink) Old 10-01-2011, 11:49 AM
Administrator
Zmann's Avatar
some trucks experience a fan clutch issue and a slight hotter temp IIRC
seems like the later flash caused this
solution plug the pigtail in to an EGR valve even if u have a full delete
Cheezit has confirmed this
DTR's Donation page
RIP DTR Ron
Zmann is offline
