Coolant Flush Chemicals - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 09-25-2011, 11:31 PM Thread Starter
I am looking to get more information about all the chemicals needed for a coolant flush. I have heard about Restore, Restore +, and VC-9.
Ok what is the purpose of each? In which order do you use the chemicals? Where can you aquire the chemicals?
2006
F350, 6.0, CC, SWB, VEGISTROKE, AD2, ARP's, OEM Gaskets, Pmax, 200cc Sticks SCT SF3, FICM Tunning, Custom ZOODAD, Coolant Filter, EGR Delete, Smoked Cab Lights, 6" Mitre Stacks, 8" 4-link Lift, SS-M16 37/13.50/20 SURE WAS NICE WITHOUT THE ADS
YoungMT Hick is offline
post #2 of 15 (permalink) Old 09-26-2011, 12:01 AM Thread Starter
Re: Coolant Flush Chemicals
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
2006
post #3 of 15 (permalink) Old 09-27-2011, 01:50 AM
strokin6L's Avatar
Use restore first then restore+ second. the VC-9 is ford's version of the restore+.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #4 of 15 (permalink) Old 09-27-2011, 02:00 AM
<sideways skyscraper
Silverback's Avatar
Not sure on the first 2 but VC-9 is designed to remove rust from iron. Its extremely corrosive
06 CCLB 8" lift 37s 22s 8300#
[email protected]
Silverback is offline
post #5 of 15 (permalink) Old 09-27-2011, 12:01 PM Thread Starter
ok well what is better vc-9 or the restore's? I bought the VC-9 for $26 thought that was a little high. Should i return it and go with restore and restore + or keep the vc-9 and get another quart?
2006
post #6 of 15 (permalink) Old 09-27-2011, 01:16 PM
strokin6L's Avatar
VC-9 is the exact same thing as restore+. If you are going to do a flush....you need to flush with restore first, then flush with restore+ or ford's VC-9. I paid around $50 for a gallon of restore+. I just flushed my coolant system a couple months ago. I also back flushed it 3 times.
post #7 of 15 (permalink) Old 09-27-2011, 11:55 PM
Silverback's Avatar
vc-9 will do just fine, how many did you buy? The workshop manual procedure calls for 2 quarts.
[email protected]
post #8 of 15 (permalink) Old 09-28-2011, 12:23 AM Thread Starter
Ya I just bought one quart. Need to get a second one. So would you say get a gallon of restore and one more quart of vc-9. Of just go for restore +. Trying to figure out what's cost worthy and effective.
2006
post #9 of 15 (permalink) Old 09-28-2011, 12:26 AM
Get the restore. It removes the silicates which clog the egr cooler.
2016 F550 6.7 9' Dump work truck
2006 F350 6.0 Auto 95k miles. Sct programmer. 5 inch exhaust. Blue spring mod. Suspension mods and 35's.
1997 F350 7.3 Reg cab. Exhaust, coolant filter, front 2.25 PMF Rsk with Superduty Leafs.
gtmustang00 is offline
post #10 of 15 (permalink) Old 09-28-2011, 12:59 AM Thread Starter
Restore Coolant System Cleaner Gallon, CC2610, Fleetguard Cummins
Is this the right stuff?
2006
