Trans Mods for 600hp? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 09-23-2011, 04:08 AM Thread Starter
mehaffey's Avatar
Ok, I have never dynoed my junk, but I hope to be somewhere upwards of 500hp. I had my trans "built" locally. The guy is known for building preformance tans and built my buddy's allison who was running twins and ran it all the time at the track (never had any trouble). Well after him tearing into mine, it left me on the side of the road today. Now I DD my truck. I dont tow heavy (8k# max) and its never been to the track or ridden hard. Just the occassional "I need to be reminded what I'm driving" thing. This trans has been together less than 6 months and 10k miles. Is this normal? I havent really looked at it or done any troubleshooting as I was so disgusted. I will probably change filter and fluid tomorrow and see if that does anything. Thoughts???
2004 crew cab 4x4. 180cc RCD injectors, II 62/80 Turbo, FASS 150, S&B intake, 4" turbo back, EGR delete, ARP studs, Innovative tuning, Precision Industries Torque Converter, Transgo Shift Kit, Billet Trans input, Edge insight,
mehaffey is offline
post #2 of 25 (permalink) Old 09-23-2011, 04:34 AM
6.0..........
STRAIGHTSTROKEN04's Avatar
Re: Trans Mods for 600hp?
It wouldnt hurt to look around see whats whats smell the fluid see if it smells burnt, see if there are any codes. What happen did it make a noise, shift weird, not go into gear, what did it do before it left you on the side of the road ? Then take it back to him and see what he says, did it have any kind of warrenty ? See if he cant figure out what went wrong. Then go from there. There is a guy that always has a answer or a direction to point someone in for there trans. He was high up when it came to ford trans so he knows his stuff. Hopefully he will chime in, if not post it in the trans section or ask for this to be moved there.
04 H-D Edition, Intake/exhaust/SCT
STRAIGHTSTROKEN04 is offline
post #3 of 25 (permalink) Old 09-23-2011, 04:39 AM
i like to party
pizza pig's Avatar
Even fresh Mercon SP or LV smells burnt before its even put into the trans, so its kind of hard to tell. What fluids are you using in your transmission?
Also, whats really the issue, does it go into all gears we need some more info here.
Better off just send it to Doug at GoGo Diesel or Twisted diesel and have them fix it, Those are the only two I would trust
pizza pig is offline
post #4 of 25 (permalink) Old 09-23-2011, 08:02 AM Thread Starter
mehaffey's Avatar
Actually I first noticed when I left to head to work that the linkage felt "different" when shifting into drive. But being being half asleep and running late I really didnt think about it. Then heading home I was dirving down the road about 55-60 and it just started half-a$$ pulling. It wasn't free revving, but wasnt completely pulling like it was. and it just got worse. I pulled over. The temp was fine. But I let the truck set about 15 min then started it and it did ok. Then in about a mile it did the same thing. Again, the trans temp never got hot or anything out of the ordinary. But it seems like the linkage is not dropping into drive like it should. Now reverse works fine... so ...idk. Im no trans guy at all.
mehaffey is offline
post #5 of 25 (permalink) Old 09-23-2011, 08:03 AM Thread Starter
mehaffey's Avatar
As for my fluids to be honest I dont know. I have not changed the filter or fluids since the build (got truck back in May) Should I try that first?
mehaffey is offline
post #6 of 25 (permalink) Old 09-23-2011, 04:14 PM
cadwell08's Avatar
my 07 just did the same thing 2 days ago .. let me know whats wrong with it when u get it fixed
cadwell08 is offline
post #7 of 25 (permalink) Old 09-23-2011, 08:22 PM Thread Starter
mehaffey's Avatar
ok. went and checked fluid color and level. THey both look fine. Got in the truck and it'll shift into reverse, but shifter will not go down even into neutral, unless you back the truck up a little then try shifting down into N,D,1,2
mehaffey is offline
post #8 of 25 (permalink) Old 09-25-2011, 05:54 PM Thread Starter
mehaffey's Avatar
Moved this thread to trans section but had no interest so I moved it back to the 6.0 performance section bc I was getting the most help here.
No one seen this before?
I talked with a guy I work with who rebuilds transmissions on the side and he said it sounds like something wasn't lined up in the valvebody. I honestly have NO idea.
I will be calling the mechanic who built it tomorrow to get his input.
mehaffey is offline
post #9 of 25 (permalink) Old 09-25-2011, 09:06 PM
Administrator
Zmann's Avatar
Mark Kawolski
hangs out in the transmission section
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 25 (permalink) Old 09-25-2011, 11:42 PM
Redneck6.0L's Avatar
My dually has a honest 600hp that I've used since spring towing 10k plus most of the time. Stock trans. Eric (innovativediesel) tunes the truck and it finally crapped to bed this weekend. A built trans should last at 600 for at least a year you would think
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
