Project "Farm Truck" motor build - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-22-2011, 06:03 AM Thread Starter
farming_stroker7710's Avatar
Looking to start a new project truck. I'm aiming for something along the line of ellertons twin turbo tow rig. I planned on starting from scratch, building kind of a hybrid motor using the better parts from different years. Can anybody give me some idea of where to start as far as what years had the best block, heads, hpo system etc...
Any help is appreciated thanks, Matt
farming_stroker7710 is offline
post #2 of 13 (permalink) Old 09-22-2011, 10:04 AM
HaysKSFirefighter's Avatar
Re: Project "Farm Truck" motor build
Sub'd
2007 F350 CCLB FX4 ZF6 with some stuff
HaysKSFirefighter is offline
post #3 of 13 (permalink) Old 09-22-2011, 11:18 AM
Sponsor
04stroker's Avatar
05-07 has a bigger water pump and I think the heads are supposed to be better. The oil rails are bigger on 05-07 but they have more o rings so I've seen those leak more often.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #4 of 13 (permalink) Old 09-22-2011, 02:06 PM
Redneck6.0L's Avatar
awesome, keep us posted
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
post #5 of 13 (permalink) Old 09-23-2011, 04:46 AM
94.5 Stroker's Avatar
will everything swap out, thinking bout getting a reman crate motor to start a build on an 03, will the 05 motor swap right in?
95 F250 RCLB- super duty axles, PMF RSK, PMF adjustable track bar, v codes, air bags, hydro boost, intercooled.
Sold: 94.5 ECLB 08 ECLB
94.5 Stroker is offline
post #6 of 13 (permalink) Old 09-23-2011, 08:15 PM Thread Starter
Yes an 05 will drop right in place but different years have different pros and cons, like I think 07 heads have a thicker base versus previous years to decrease the chance of warpage. I would try and find a good used block and just rebuild the bottom end myself if I was you, a lot cheaper the a Ford reman, that's just what I planned on doing.
post #7 of 13 (permalink) Old 09-25-2011, 03:52 AM
Sounds like a good idea, so i can actually piece together a motor with parts from all the best parts of each year?
post #8 of 13 (permalink) Old 09-25-2011, 04:39 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
You can to an extent. 05-07 parts are all gonna be the same, main issues is putting 04.5-07 parts on a 03 block. Here is the list of different things.
2003-early 04 and 04.5 to 07 trucks - Different HPOP, HPOP Cover, Branch Tubes, Oil rails, ICP location, Water Pump, Front Cover, Intake Manifold, and elbow, FICM bracket is different, Crank Case Vent, Glow Plug Relay Mouting bracket, Studs vary on 18 to 20mm on later blocks, Trans they do bolt up but the TCM needs to be flashed correctly, Rocker Boxes. All I can think of right now.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #9 of 13 (permalink) Old 09-25-2011, 05:25 AM
Banned
Smut's Avatar
Heres the skinny on a been there done that. Drop in a 06 07 motor.
Smut is offline
post #10 of 13 (permalink) Old 09-25-2011, 03:24 PM
I was working on my friends 2007 6.0 the other day and noticed it has 330 hp, when did that go up from 270hp?
Desertdweller is offline
