Exhaust Install Problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 09-22-2011, 01:19 AM Thread Starter
Thumbs down Exhaust Install Problem
Just finished installing RBP exhaust on 04 Powerstroke crew cab. It took quite longer than what I though. Sounds great, but the only problem I am running into is the tail end of the exhaust system with the orignial OEM hanger. After it is installed it sits directly behind my rear tire and has alot of sway. Everything is installed correctly but makes the exhaust look like crap on the truck plus it is almost on the tire. Anybody else have these problems?? Any suggestions?
SnuffCityBoy88 is offline
post #2 of 8 (permalink) Old 09-22-2011, 02:43 PM Thread Starter
Re: Exhaust Install Problem
Anybody have any suggestions??
post #3 of 8 (permalink) Old 09-22-2011, 03:04 PM
powerstrokedkid87's Avatar
not sure if it will help, but maybe some of the piping is overlapped too much, maybe see if you can stretch the pipe connections a little it, might give you a little more space on the end.
just a thought
completley stock truck...just a simple cat back system....and maybe a few other odds and ends
powerstrokedkid87 is offline
post #4 of 8 (permalink) Old 09-22-2011, 05:22 PM
Tylus's Avatar
was their kit specific for a shorbed? and do you have a longbed? many exhaust kits come with several different length sections that you utilize depending on bed length
otherwise, I'm with powerstrokedkid. You might have too much pipe overlapping at each joint.
2000 Excursion
2012 Challenger R/T
2015 Tahoe
Tylus is offline
post #5 of 8 (permalink) Old 09-24-2011, 05:13 AM Thread Starter
Don't have none overlapping. The problem is with the original OEM hanger. It will only fit into one spot on the frame, putting the piping right behind the tire.
post #6 of 8 (permalink) Old 09-24-2011, 05:15 AM Thread Starter
The kit is for a short bed which is what I have.
post #7 of 8 (permalink) Old 09-24-2011, 04:24 PM
Tylus's Avatar
got any pictures then?
if the hanger was correct, would the new exhaust pipe line up properly? or is there not enough length?
if a new hanger and then she'll line up properly, I would shoot the company a nasty e-mail or call. Hopefully they'll send a new one that works
until then, you can get generic hangers from the parts store. it's a tab that you bolt to the frame...has what looks like tire rubber and then another tab on the other end. it isn't ideal, but it'll work in a pinch until a better method is found
2000 Excursion
2012 Challenger R/T
2015 Tahoe
Tylus is offline
post #8 of 8 (permalink) Old 09-24-2011, 05:04 PM
black_pstroke's Avatar
:WHS: post some pics of the issue
2009 F-250 FX4 Icon, Toyo, Fuel, Bilstein, IDP/SCT, Flopro
black_pstroke is offline
