fuel system upgrades - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-22-2011, 01:02 AM Thread Starter
injected79's Avatar
Hey guys I finally put a fuel pressure gauge in the truck, and like I thought at wot fuel pressure drops in a hurry to 4 psi. So I'm wondering what my options are for replacement/upgrade. Currently run swamps 58v ficm, cai, exhaust and matts srl tune. No current plans for injectors but maybe a set of 190,s or so down the road. But what are your suggestions on what way I should go with this. Thanks for your opionins
Sold puller-1997 f-350 12 valve 913 p-pump, big charger, big fuel, SBC, and so on
Puller-1979 Ford S/B, 60 front, 10.25 rear, 5.13 gears, ockers, 503 BBF, C6 with 2500 stall
DD-2005 F-250 c/c s/b 6.0L lariat, 6" lift, 35"m/t's, 18x12's, 58v ficm, gearhead tuned, 6.4 banjo's, raptor fuel system, 5" exhaust and a CAI
**No Non-sponsor Links**
injected79 is offline
post #2 of 10 (permalink) Old 09-22-2011, 02:42 AM
Sponsor
Dave At BD Power's Avatar
Re: fuel system upgrades
Sorry not a direct answer to your question but typically we run the factory pump and a regulated return line kit
Dave
Dave Dias
Dave At BD Power is offline
post #3 of 10 (permalink) Old 09-22-2011, 05:23 AM
Ian123's Avatar
Have you heard about the blue spring upgrade? Its an updated fuel pressure regulator spring that puts fuel pressure at the bowl at around 65 psi. If you are getting down to 4 psi, I would definitely say either your spring or fuel pump is bad.
2007 F-250 CCLB Lariat FX4 6.0L
Originally Posted by fuekear View Post
I just blow my heads off the block once a year. Keeps nice clean antifreeze in it, although not that cost effective it sure is fun.
Ian123 is offline
post #4 of 10 (permalink) Old 09-22-2011, 01:14 PM Thread Starter
injected79's Avatar
If he spring was weak woundnt the pressure lower all the time. I would be more apt to think the supply pump. But that's why I'm asking questions also
post #5 of 10 (permalink) Old 09-23-2011, 02:17 AM
rdunagan's Avatar
id say its the pump. and if its the pump id put an airdog on it vs a stocker if your plans are to go bigger one day. i would think if the fuel pressure was that low you would have popped injectors by now or atleast they would be studdering quite a bit from the lack of basically no fuel. did you double check the install of the pressure gauge to make sure its all correct. not doubting the work just depending on what kinda gauge ie glowshift they have problems with the senders
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me, fusion bumper with rigid led lights
rdunagan is offline
post #6 of 10 (permalink) Old 09-23-2011, 09:35 AM
PursuitInterceptor
HeavyAssault's Avatar
What are your pressures during normal driving??
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #7 of 10 (permalink) Old 09-23-2011, 09:56 AM
Sponsor
04stroker's Avatar
If it's the pump I would suggest an airdog.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #8 of 10 (permalink) Old 09-23-2011, 12:31 PM Thread Starter
injected79's Avatar
Under normal driving it stay right about 50 psi. I think that is why I haven't had injector issues. I think for right now I may just buy an airmotive pump and regulator then do the banjo bolts and the spring.
post #9 of 10 (permalink) Old 09-23-2011, 12:38 PM
With the Airmotive regulator you can do away with the spring. Your regulator willset the pressures not the factory spring. Do a return regulator set up for more consistant pressures.
lenzhotrod is offline
post #10 of 10 (permalink) Old 09-24-2011, 01:49 AM Thread Starter
injected79's Avatar
Well i ended up going with a raptor 150 high pressure pump kit, has a max of 75 psi, and i also picked up a Jegs/wix fuel filter water serparator that flows 40 gpm and it filters to 7 microns. Now just going to look into upgrading the banjo bolts.
