Coolant filter needed still? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-20-2011, 03:12 AM Thread Starter
99whitestroker's Avatar
I have 191,000 miles on the truck. Just replaced injectors deleted egr and the list goes on. Most importantly got rid of the egr and new oil cooler. Do I still need to put this kit on? I would of thought it was all out but u guys tell me
2006 F350 cclb.. Sinister egr delete with up-pipe, Warren 155's, straight pipe,Afe intake, sct x3 with tunes by eric @ innovative..sinister coolant filter kit...retro 6k HIDS..edge cts monitor
sold:97' F250eclb OBS 111,000 fresh miles. swamps Ts 6 pos. chip, diy 6637 kit, 3inch dp, 5inch exhaust,1800triple disc convertor and rebuilt trans
99whitestroker is offline
post #2 of 13 (permalink) Old 09-20-2011, 03:21 AM
06-sixoh's Avatar
Re: Coolant filter needed still?
Do you already have the kit? I would still install. Do you see all that crud they pull out of those filters?
2006 F250 CCSB FX4 Lariat
GlowShift Tinted gauges, Recon Clear Cab Lights, Diamond Eye Duals, SRL Files, 2.5" rize leveling kit, F350 Rear Blocks, PHP Tuned FICM, Retro Solution 6K HID's, DieselSite Coolant Filter...
2011 Oxford White SuperCrew EcoBoost FX2
06-sixoh is offline
post #3 of 13 (permalink) Old 09-20-2011, 01:21 PM Thread Starter
Yea I was leaning towards doing it lol just didn't k ow if it was worth while
post #4 of 13 (permalink) Old 09-20-2011, 02:16 PM
06-sixoh's Avatar
I would
06-sixoh is offline
post #5 of 13 (permalink) Old 09-20-2011, 02:17 PM Thread Starter
hhahah ordered lol..figured it wouldnt hurt anything lol..never go wrong with filtration
post #6 of 13 (permalink) Old 09-21-2011, 04:29 AM
06-sixoh's Avatar
The kit is pretty cheap isnt it; somewhere around $100 or something...
06-sixoh is offline
post #7 of 13 (permalink) Old 09-21-2011, 12:43 PM
No, an aftermarket coolant filter isn't needed.
Basically, the choice is yours:
- Continue to use the OEM coolant filter as-is and, once it plugs, get it replaced for around $2400 +/-. This price assumes, of course, that the OEM coolant filter getting plugged doesn't take out the heads or wrist pins etc.
- Install an aftermarket coolant filter for about $120-$140 and then replace the aftermarket coolant filter at about $10 each time (500 miles, 1000 miles, then one year or so thereafter).
Your choice. Choose wisely.
Good luck.
FTG-05 is offline
post #8 of 13 (permalink) Old 09-21-2011, 01:36 PM
3brorce's Avatar
Originally Posted by donzimama View Post
I have one I will sell for 120 shipped
What kind is it? Come with ball valves and filter?
03 6.0 Full EGR delete, S&B CAI, 4in turbo back, 70hp injectors, Moded Banjos, fuel spring mod, GearHeads, RCD, IDP and TSD tuned, trans temp, boost, egt, fuel press, MIA
08 6.4 4in dp. 5in TBE. S&B, Studs, EGR delete, No limit elbow/CAC pipe, Spartan, TSD, QTP and IDP LW tuned
07 5.9 5in TBE, Goerend, Fass, EFI Anarchy Diesel Tuning
3brorce is offline
post #9 of 13 (permalink) Old 09-21-2011, 04:16 PM Thread Starter
Where's the stock coolant filter? I ordered the sinister kit came in today
post #10 of 13 (permalink) Old 09-21-2011, 04:20 PM
'05 Excursion
Term3's Avatar
It's in the valley of your 6.0 engine and it's called "the oil cooler".
Term3 is offline
