205cc and rcd race 66mm - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 60 (permalink) Old 09-20-2011, 01:57 AM Thread Starter
stroker57's Avatar
what do you think this set up would 205/100 with rcd 66mm race non vgt turbo sould put me in the low 12s right ?
some parts to try and go fast
stroker57 is offline
post #2 of 60 (permalink) Old 09-20-2011, 02:36 AM
BRING DA AMBALAMPS
stroke of luck's Avatar
Re: 205cc and rcd race 66mm
low 12's....prolly not. mid 12's...yeah
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #3 of 60 (permalink) Old 09-20-2011, 03:31 AM
<sideways skyscraper
Silverback's Avatar
high 12s if you can spool it off the line
06 CCLB 8" lift 37s 22s 8300#
[email protected]
Silverback is offline
post #4 of 60 (permalink) Old 09-20-2011, 03:52 PM
strokin6L's Avatar
i've heard good things about RCD turbo's. Their turbo's aren't much different that anyone else's. RCD's turbo's along with trusted's, II's and some others start out as BW chargers. Each company does their own little touches such as drain lines, feed lines, pedistal, adapter flange, polished housings. I wouldn't worry about doing business with them. I think most people had issues with RCD injectors is because of installation for the first time. I had issues with my very first set of Dynomite Diesel injectors i got for my truck. It was in no way DP's fault...it was mine. O-rings got cut when i had installed two injectors. Down the road few months later i had two injectors loosen up. couple months after that the other two on the same bank loosened up also. Come to find out i didn't clean out the injector holder bolt holes before i torqued them. When i got the casserly sticks...i was very thorough when i installed them. Not to mention torqued them a few ft lbs more than the factory spec. A very thorough installation of injectors is key. And for the first time installer that don't know, will have issues. I think the guys that had issues with the RCD injectors were first time installers. I also understand that sometimes there will be issues that don't result from installation error, but RCD i believe is a great company that stands behind their products and will take care of issues that aren't a result of installation error. I myself wouldn't hesitate from doing business with them again. I've talked to Josh, Ron, and Jared and all seem really nice.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #5 of 60 (permalink) Old 09-20-2011, 04:26 PM
i like to party
pizza pig's Avatar
I've talked to Josh about turbos and he was pretty easy going and knew what he was talking about... but im sorry they dont know how to rebuild an injector for ####... a buddy of mine when we were installing his 180's from rcd they injector top fell off, and has another screw missing on three others...
pizza pig is offline
post #6 of 60 (permalink) Old 09-20-2011, 04:40 PM
i like to party
pizza pig's Avatar
i was quoted for a 62/68/70 with bat from bill for $1650... then you need the pedestal kit from BD or Turbonetics.... RCD turbos come with all the lines pedestal, adapter flange etc so its a really good deal
post #7 of 60 (permalink) Old 09-20-2011, 04:41 PM
strokin6L's Avatar
only bad thing about bullseye turbo's is they don't have the normal sized turbine housings. So you'd hafta buy the bullseye turbo then buy the housing you want from someplace else.
post #8 of 60 (permalink) Old 09-20-2011, 04:52 PM
strokin6L's Avatar
Exactly! By the time you get the bullseye turbo then the installation stuff for it(adapter flange, drain line, feed line, pedistal)...Your spending as much if not more than a RCD turbo. $2450 for an RCD 66mm turbo with everything for the install isn't bad. Heck, i paid $2450 for the 64mm turbo i have on my truck now...and RCD's 64mm turbo is $2250.
post #9 of 60 (permalink) Old 09-20-2011, 04:59 PM
i like to party
pizza pig's Avatar
when i spoke with Bill he said i he could build me any combination turbo I wanted.. can you explain further?
post #10 of 60 (permalink) Old 09-20-2011, 05:06 PM
strokin6L's Avatar
Well, i was under the impression that you can only get what turbine housings they offer for the turbo you want. The only normal size housing i see that guys use is the .70a/r for the 66mm. Here's a list of them
Bullseye Power Turbos
The other sizes just seem either way small or way large
