running too cool?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-18-2011, 06:09 PM Thread Starter
99whitestroker's Avatar
running too cool??
hey guys, so i just got done putting my edge cts in and took it for a testdrive.. i found my ect vs eot difference good with the most diff being 11 deg..( it better be since i just repalced it) but i found my ect and eot stay around 155-160 and trans about 150 also. now i much rather have it this way than too hott lol. but doesnt it seem a little too cool to you guys?? oh and ambient temp was 70 outside
2006 F350 cclb.. Sinister egr delete with up-pipe, Warren 155's, straight pipe,Afe intake, sct x3 with tunes by eric @ innovative..sinister coolant filter kit...retro 6k HIDS..edge cts monitor
sold:97' F250eclb OBS 111,000 fresh miles. swamps Ts 6 pos. chip, diy 6637 kit, 3inch dp, 5inch exhaust,1800triple disc convertor and rebuilt trans
99whitestroker is offline
post #2 of 16 (permalink) Old 09-18-2011, 06:58 PM
Re: running too cool??
How long did you drive it?
Once warmed up, ECT should be low to mid 190's and EOT around 200+ running down the road unloaded.
2006 6.0L, Lariat, 2WD, SWB, 3.73's
dieselmac is offline
post #3 of 16 (permalink) Old 09-18-2011, 07:04 PM Thread Starter
about 35miles down the interstate
post #4 of 16 (permalink) Old 09-18-2011, 07:20 PM
Yea that is a little cold.
When I was in Tahoe for a while during the winter my temps would never get above 160. So I used a piece of card board to block some of the air flow. That brought my temps up to 190ish and trans temps got up to 140. It also held the heat in the eng longer.
With any engine running cold, there will be water build up in the engine due to the temps not getting high enough to evaporate the water that is taken in from the air.
smokersteve is offline
post #5 of 16 (permalink) Old 09-18-2011, 07:47 PM
i like to party
pizza pig's Avatar
your thermostat is stuck open, replace the thermostat you should be seeing 190ish ECT and EOT temps when warmed up
pizza pig is offline
post #6 of 16 (permalink) Old 09-18-2011, 08:02 PM Thread Starter
already checked the thermostat it opens properly
post #7 of 16 (permalink) Old 09-18-2011, 08:03 PM
Administrator
Zmann's Avatar
too cool isn't good for these trucks
whats your outside air temps when you got your readings?
EDIT duhh 70
Hmm been a while since I have seen 70 lol but mine would be around 184 ECT
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 16 (permalink) Old 09-18-2011, 08:12 PM Thread Starter
what happens if they run too cool?
post #9 of 16 (permalink) Old 09-18-2011, 08:34 PM
Administrator
Zmann's Avatar
from deselsite Ignore the 203 t stat referance because it's for a 7.3
but you get the idea
Answer: You want the engine oil/water temps to be warmer so you get a cleaner, more complete combustion. This can actually bring exhaust gas temperatures DOWN. Diesel ignites from heat of compression. The idea is to compress the air charge to build enough heat to light the fuel, but if it's fighting against a low engine heat, the fuel will ignite, but not as complete as if the cylinders were just a bit warmer. The more complete the combustion, the cooler the exhaust temperatures. Diesel fuel combustion tends to complete best at temps above 200*. An added benefit from using the 203o thermostat is better working cab heaters in the cold months. Another added benefit is better fuel economy. We have seen everywhere from 1-4mpg increases. This depends on climates, driving habits, etc. Even a modest .25 mpg increase will pay for the thermostat in a few
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 16 (permalink) Old 09-18-2011, 08:39 PM Thread Starter
Cool thanks for the info zmann.. I'll try some cardboard tomarrow when I take my grill off to do my HIDS!
