Looking for a leveling kit... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-10-2011, 07:15 AM Thread Starter
sesco4's Avatar
I'm wanting to level my 05 F250 and don't really know which way to go. I've had a couple people suggest the Icon kit but I don't really want to spend a 1000.00 dollars to level my truck. I've also seen lots of cheaper kits on ebay. I know not everybody is spending big bucks to level their trucks so which kits are they using.
Thanks
sesco4 is offline
post #2 of 9 (permalink) Old 09-10-2011, 02:08 PM
Twan's Avatar
Re: Looking for a leveling kit...
I'm running the Pro Comp 2" kit. It was around $100.
2006 CCLB 4x4 King Ranch 2"lift 35's, S&B, sct tunes by Innovative, Quick Tricks, Powermax, 6.4 Banjo bolts, coolant filter, edge insight, 4" turbo back.
Twan is offline
post #3 of 9 (permalink) Old 09-10-2011, 03:03 PM
06-sixoh's Avatar
Im running the RIZE 2.5" kit with F350 blocks in the rear.
I would suggest looking on the classifieds for a couple of weeks. I have bought almost all my leveling kit used for all my trucks, and have neve had an issue. You can usually find nicer kits for less than $100.
2006 F250 CCSB FX4 Lariat
GlowShift Tinted gauges, Recon Clear Cab Lights, Diamond Eye Duals, SRL Files, 2.5" rize leveling kit, F350 Rear Blocks, PHP Tuned FICM, Retro Solution 6K HID's, DieselSite Coolant Filter...
2011 Oxford White SuperCrew EcoBoost FX2
06-sixoh is offline
post #4 of 9 (permalink) Old 09-10-2011, 08:02 PM
if you want to lift it 2" or less, you can just use spacers. any more, you need to buy a kit and get bigger shocks.
smokersteve is offline
post #5 of 9 (permalink) Old 09-10-2011, 09:33 PM
PSN
Custom-Diesel.com has a 2.5" kit with shock extenders for $99
McCrackin is offline
post #6 of 9 (permalink) Old 09-16-2011, 02:53 PM
Just get some new coils from rough country, they will raise it up about 1.5" or so. bout $160
06 F 250, Leveling kit, BFG 35s, 4 in. straight, EGR delete by RCD, TS MP 8, SCT with custom tunes to come.
calebh717 is offline
post #7 of 9 (permalink) Old 09-16-2011, 11:37 PM
blead Ford Blue
gjoski515's Avatar
Send a message via Yahoo to gjoski515
skyjacker make a 2.5 with new front coils for the front and a add a leaf for the back, plus u need the f350 blocks the price was 250 when i did mine iabout 3 yrs ago, i prefer new coil, gave away the 2.5 spacers i had didnt look like a good idea
gjoski515 is offline
post #8 of 9 (permalink) Old 09-16-2011, 11:48 PM
06-sixoh's Avatar
I dont have any complaints. I've run them on two off my vehicles without issue. One was on my jeep, with sway bar disconnects, and had it flexed to the max, and they seated just fine
06-sixoh is offline
post #9 of 9 (permalink) Old 09-18-2011, 03:28 PM
Thanks
I went with the RCD 2.5" level kit, new coils bilstiens and alignment cams. Very nice kit and rides much better than stock. You need the cams in there I tried it out with out before putting them in and the truck felt like it wanted to wander.
Link:
Ford F250 4wd
2006 Fthreefidy FX4 Lariat, ARP studs, EGR delete, 4" TB BD exhaust, RCD 2.5" level kit w/Bilsteins, Nitto Terra Grapplers, SCT Livewire Matts SLR++, STC done, Dieselsite coolant filter,Liberator Y pipe, ELC coolant change
To do list:fluids changed out to synthetic,HID's.
DerwoodF350 is offline
