Question on guages - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-08-2011, 02:23 AM Thread Starter
99whitestroker's Avatar
Question on guages
Ok guys my truck has a boost guage in it from the factory my buddy told me to get one anyway when i get my new guages for my pillar. What's your thoughts? Also just bought a cts so I planned on running it with the guages also. Anyone doing this also?
2006 F350 cclb.. Sinister egr delete with up-pipe, Warren 155's, straight pipe,Afe intake, sct x3 with tunes by eric @ innovative..sinister coolant filter kit...retro 6k HIDS..edge cts monitor
sold:97' F250eclb OBS 111,000 fresh miles. swamps Ts 6 pos. chip, diy 6637 kit, 3inch dp, 5inch exhaust,1800triple disc convertor and rebuilt trans
99whitestroker is offline
post #2 of 12 (permalink) Old 09-08-2011, 02:29 AM
professional slacker
alwil's Avatar
Re: Question on guages
How many gauges are you going to get on top of the CTS?
I have pyro,boost,fuel and a scangauge2.....if I could do it again I would have left out the boost gauge as its kind of a wast when I have one in the dash .
alwil is offline
post #3 of 12 (permalink) Old 09-08-2011, 02:40 AM
09 6.4
webb06's Avatar
personally i like the looks of having a boost gauge that matches my other gauges but its totally up to you. the stock gauge works just fine, just depends if you want to spend money on one
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #4 of 12 (permalink) Old 09-08-2011, 11:22 AM Thread Starter
i was going to run fuel, pyro trans, and boost and monitor everything else with the cts but it almost seems like overkill.
post #5 of 12 (permalink) Old 09-08-2011, 05:27 PM
Twan's Avatar
I would get a boost gauge because the one that the truck has or edge is a little off. But that's just me.
2006 CCLB 4x4 King Ranch 2"lift 35's, S&B, sct tunes by Innovative, Quick Tricks, Powermax, 6.4 Banjo bolts, coolant filter, edge insight, 4" turbo back.
Twan is offline
post #6 of 12 (permalink) Old 09-08-2011, 06:42 PM Thread Starter
Any other input?
post #7 of 12 (permalink) Old 09-08-2011, 08:52 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Your dash boost gauge isnt always correct either. I have 8 gauges in my truck as of right now. I dont trust factory gauges period.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #8 of 12 (permalink) Old 09-08-2011, 10:21 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
The factory boost gauge isnt accurate on my truck however the boost that the PCM calculates/sees IS accurate. I had a mechanical boost guage and it correlated perfectly to what my CTS was reading for boost but both were about 2 psi higher than that little guage on the dash.
Personnally I like the CTS so much I removed all of my gauges and monitor everything with it. You can put in the expandable EGT probe, universal pressure sensors for fuel and oil pressure if desired and universal temperature sensors for trans, diffs, what every you want and the best part is I get to keep my grab handle. I am a tall guy but plan to lift my truck and dont want short people who get up into my truck yanking on the steering wheel or pushing down hard on the door. Now unless you really like the look of gauges, it is cheaper to just expand your CTS to monitor what you want it to. JMO.
Nate
windrunner408 is offline
post #9 of 12 (permalink) Old 09-09-2011, 01:43 AM Thread Starter
Yea I'm thinking I'm going to do four pillar pod with isspro ev 2's with pyro, boost, fuel, and trans and run the cts for Eot and Ect just not sure what else to monitor with the cts.. Thinking icp.. What do u fellas monitor with the cts
post #10 of 12 (permalink) Old 09-09-2011, 01:50 AM
Almost broke
midnight2004's Avatar
I have 4 on the pillar: Trans temp, boost, egt, and fuel pressure.
4 overhead: coolant temp, oil temp, low oil pressure, high oil pressure
Scanguage: FICM output volts, FICM input, coolant and oil temps.
I like gauges!
Chris
2004 F250 Lariat 6.0L
Torqueshift, 4x4, Supercab, Shortbox.
midnight2004 is offline
