Bad injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-29-2011, 06:27 PM Thread Starter
Bad injectors
Well shop just told me that I have 4 bad injectors in my 2003 6.0L. Since I have 4 bad injectors and I was planning on upgrading eventually anyways I guess its time to start looking and getting some opinoins. I use my truck as a daily driver and tow rig so I'm not looking for huge HP gains just a little more then stock injectors provide.
So I am looking for some addvice on which would be the best to go with for my application? Any help would be greatly apperciated I would like to have my truck back up and running soon.
I currently have EGR delete, cold air intake, 4 inch turbo back exhaust, and an edge juice with attitude on my truck.
acplowboy84 is offline
post #2 of 9 (permalink) Old 08-29-2011, 06:35 PM
Irate Sales Guy
greenbeast's Avatar
Re: Bad injectors
For a little more the 155cc injectors is what I would recommend, but be prepared to do studs sometime in the future!
97 F-250 CC 350/200's, Intercooler, Billet S468, T-4 mount, BTS trans, Irate Electric Fuel, BTS Dual Pumps, Water Meth, NOS, ARP studs, Comp 910 springs, Gearhead tuning.
503-435-9599 Call or Text!
greenbeast is offline
post #3 of 9 (permalink) Old 08-29-2011, 06:37 PM
stoker04's Avatar
Re: Bad injectors
You also may want to look at getting SCT and some custom tunes if you run the 155cc injectors.
2004 F350 6.0 ECSB Lariat. All the normal stuff
stoker04 is offline
post #4 of 9 (permalink) Old 08-29-2011, 10:04 PM Thread Starter
Re: Bad injectors
So thinking of going with a set 155cc injectors with a regulated return. Question about doing the heads though. If I go a head and do head studs while I already have it turn down other then checking the block and head to ensure they haven't wrapped is there anything else I should have done to them since they aren't leaking now?
post #5 of 9 (permalink) Old 08-29-2011, 10:09 PM
stoker04's Avatar
Re: Bad injectors
Replace your oil cooler while its apart.
Then I'd look into a coolant filter for your truck.
stoker04 is offline
post #6 of 9 (permalink) Old 08-29-2011, 10:45 PM
Sponsor
04stroker's Avatar
Re: Bad injectors
Have the heads shaved even if they are the least bit warped and Ive never seen a set that aren't.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #7 of 9 (permalink) Old 08-29-2011, 11:11 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: Bad injectors
I would only add to do a modest coolant flush and put some ELC in there.
Yep, get the heads fully checked out. Magnafluxed, pressure checked, checked for flatness, valve job if necessary, etc. If it is worth doing, it is worth doing right the first time.
Nate
windrunner408 is offline
post #8 of 9 (permalink) Old 08-29-2011, 11:52 PM
Sponsor
04stroker's Avatar
Re: Bad injectors
Let me know if you need anything. I have coolant filters in stock and can get you anything else I dont have in stock.
holdersdiesel.com
post #9 of 9 (permalink) Old 08-30-2011, 12:06 PM
stoker04's Avatar
Re: Bad injectors
Can you PM me a price on a coolant filter?
Thanks Zach
stoker04 is offline
