EGR cooler delete can be done without lifting intake - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-25-2011, 04:43 AM Thread Starter
Maybe some of you guys have already figured this out, but we figured out that the egr cooler removal does not require lifting the intake (though river city diesel said we had to). all that's required is a grinder with a minimum of a 5" cut off wheel. this was done on an 04 truck (03 engine) while we cleaned the turbo. if you rotate the cooler and then lift it slightly over the heat shield, it will clear. then, if you really want to save the cooler, a welder can tig wild the tit back onto the cooler. this is on a truck with stock fueling mind you, so dad did not want to lift cab/install head studs/do heavy mods, etc.
04 Cummins 2500...not stock.
dad's: 04 f350 6.0..basically stock
Sooter is offline
post #2 of 6 (permalink) Old 08-25-2011, 12:07 PM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: EGR cooler delete can be done without lifting intake
meh... I can probably lift intake and set it faster than just cutting that....
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #3 of 6 (permalink) Old 08-25-2011, 01:16 PM
Haters Gonna Hate
Fordfreak4life's Avatar
Agreed
Fordfreak4life is offline
post #4 of 6 (permalink) Old 08-25-2011, 03:58 PM
Hood Rich
CTC DEEZUL's Avatar
plus you'll still have a valuable core... Many guys are finding out 'new' to them methods, but really its just backyard work...
via Beans Toonz
DI SS Up-Pipe
GTP38R
post #5 of 6 (permalink) Old 08-25-2011, 04:10 PM
Yeah but usually you still have to replace the oil cooler to do the job correct... Just my 2cents
UnknowDiesel is offline
post #6 of 6 (permalink) Old 08-26-2011, 05:17 AM
harley master
hawgdoctor's Avatar
Atleast if you want your truck to live a happy life......
06 ccsb-gone but not forgotten
00 rclb-a little of this and that....
hawgdoctor is offline
