Modified Up-pipe install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-23-2011, 10:34 PM Thread Starter
stoker04's Avatar
So my buddy John(JD F350)has a 6 liter and he gave me one of his stock up pipes from his truck. So I decided I would cut the up pipe notch out for the Egr cooler and put another piece of steel in place of the notch. I successfully did it. I am wondering if the cab has to come off in order to put the up pipe in? Or can I access the up pipe an easier way??? Thanks Zach
2004 F350 6.0 ECSB Lariat. All the normal stuff
stoker04 is offline
post #2 of 9 (permalink) Old 08-23-2011, 10:43 PM
Re: Modified Up-pipe install
No you dont need to raise the cab. Should just be able to get to the up pipe from the top, other wise try from going underneath the truck. May have to loosen the turbo to get everything to line up correctly.
Matt07 is offline
post #3 of 9 (permalink) Old 08-23-2011, 10:45 PM Thread Starter
stoker04's Avatar
About how long does this take?
stoker04 is offline
post #4 of 9 (permalink) Old 08-23-2011, 10:51 PM
i like to party
pizza pig's Avatar
it depends how forgiving getting the ones on there off
pizza pig is offline
post #5 of 9 (permalink) Old 08-23-2011, 11:00 PM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
remove trans dipstick tube. all the access in the world
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #6 of 9 (permalink) Old 08-23-2011, 11:04 PM Thread Starter
stoker04's Avatar
Thanks guys!
stoker04 is offline
post #7 of 9 (permalink) Old 08-30-2011, 04:50 AM
About 6 beers...
2006 Fthreefidy FX4 Lariat, ARP studs, EGR delete, 4" TB BD exhaust, RCD 2.5" level kit w/Bilsteins, Nitto Terra Grapplers, SCT Livewire Matts SLR++, STC done, Dieselsite coolant filter,Liberator Y pipe, ELC coolant change
To do list:fluids changed out to synthetic,HID's.
DerwoodF350 is offline
post #8 of 9 (permalink) Old 08-30-2011, 05:14 AM
Agjake11's Avatar
Stoker04. When are you going to do the install? My egr delete I won doesn't have the up pipe with it. Think you could make another one and hook me up haha.
04 F250 - 6.UHOH. Studded and Deleted By PSE, Fueled by Warren and Aeromotive, and Tuned by Gearhead.
08 Tacoma Work truck. V6 Power nothing, Radio, AC, and 4x4
Agjake11 is offline
post #9 of 9 (permalink) Old 08-30-2011, 12:08 PM Thread Starter
stoker04's Avatar
Yeah I can do that for you man.
stoker04 is offline
