Turbo questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-15-2011, 08:58 AM Thread Starter
da94broncodude's Avatar
Turbo questions
I spent the last 4-5 hours refreshing my memory and updating it with new info on turbos, not the basic stuff the more technical stuff, was calculating trims, figuring a/r all that jazz and started looking at the aftermarket and i have a few questions.
when one refers to lets say a 62/70 turbo, what does each number represent? trim? compressor inducer? turbine exducer?
what about when a number is used alone 62mm or 66mm ie bwd uses a 62mm s300 is that the s362 listed on bullseyes site? or is it different? what about BDs 64 is that the s364 listed on bullseyes?
on a non VGT for those running them, i see some run them gated, some dont, for those that arent how are they controlling boost pressure?
is a diverter valve only needed on turbos 64mm and larger as they are a slightly large enough to create lag and this aids in reducing the lag? but on anything smaller it isnt needed?
Joey- 2006 F350 Amarillo edition- too much to list
2016 F350 Magnetic gray dually- stock with 24" alcoas
2007 F350 Silver single cab- SCT for now
da94broncodude is offline
post #2 of 3 (permalink) Old 06-15-2011, 11:10 PM Thread Starter
Re: Turbo questions
nobody huh?
post #3 of 3 (permalink) Old 06-15-2011, 11:19 PM
Big Sun fanatic
Ithumpwheniwalk's Avatar
Re: Turbo questions
give em time, my friend. there's alot of gurus on here that'll answer that and more!
here's a free bump though!
Originally Posted by da94broncodude View Post
nobody huh?
e99 F350 7.3l 6sp. 4" exhaust & dp, Adrenaline hpop (& other Dieselsite goodies), 160cc Stage 1's, D66, tunes by BTS, DIY Intake, Isspro gauges & pillar mount....
Ithumpwheniwalk is offline
