Bulletproof Parts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-13-2011, 10:06 PM Thread Starter
Question Bulletproof Parts
So I am ready to buy the parts that I need to bulletproof and just want your opinion on my list and whether I am forgetting something for the basic bulletproofing (also whether these brands are the best choice). I am planning on getting...
Sinister EGR delete kit
ARP head studs
SCT X3 tuner plus tunes from innovative diesel
MBRP 5" turbo back straight pipe (are there any other brands someone could recommend? Just because MBRP can be kind of expensive)
Also, I have heard that the ford stock head gasket is fine (as long as you put studs on the heads) and I wouldn't need the sinister black onyx gaskets, is this true (just to double check)?
mcwillig is offline
post #2 of 5 (permalink) Old 06-13-2011, 10:09 PM
Semperfidoordie's Avatar
Re: Bulletproof Parts
Subscribing as I have the same questions
2006 F-350 King Ranch 4x4
USMC/OIF Veteran
2005-2014
Semperfidoordie is offline
post #3 of 5 (permalink) Old 06-13-2011, 10:30 PM
09 6.4
webb06's Avatar
liberator performance has a cheaper egr delete kit if i recall correctly, arp's are good, definitely custom tunes from innovative or gearhead or any other reputable source, 5" exhaust isnt needed but its up to you and there are cheaper exhaust kits that do the same thing as MBRP but again its up to you, and i have used both the black onyx and oem but oem seems to be the best option
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #4 of 5 (permalink) Old 06-21-2011, 06:48 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
You will need to look at either rebuilding the oil cooler or doing a remote oil cooler system as well as changing over to ELC and adding a coolant filter such as one from sinister or diesel site.
Nate
windrunner408 is offline
post #5 of 5 (permalink) Old 06-21-2011, 07:21 PM
cadwell08's Avatar
hey i am not trying to promote any companys or anything but the cheapst exhaust i have found is most the times on farmboysdiesel its there own exhaust not name brand but they still sound good thats what i put on mine i just got 4 inch staight pipe with duals
cadwell08 is offline
