Which option is best?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-06-2011, 11:29 PM Thread Starter
09 6.4
webb06's Avatar
Question Which option is best??
Blew another head gasket after having done the first ones about 7000 miles ago. Turns out the block was not flat enough. It blew between the second and third cylinders on the drivers side. When a straight edge is placed on the block, a .002 feeler gauge can be pushed underneath of the straight edge. From what I have looked up the most that should be allowed in that 1" x 1" area is about .001. So should I strip the engine down and have the block surfaced, or would O-Ringed heads be an option? Open to any other options if there are any. Chime in with anything that is missing or if something I said was wrong, all help is appreciated!!!
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #2 of 9 (permalink) Old 06-07-2011, 02:06 AM Thread Starter
09 6.4
webb06's Avatar
Re: Which option is best??
no one has any advice or experience with o ringed heads??
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #3 of 9 (permalink) Old 06-07-2011, 06:21 AM
what gaskets did you use on the first go round?
2008 F350 Lariat 6speed!
85yota350 is offline
post #4 of 9 (permalink) Old 06-08-2011, 01:32 AM Thread Starter
09 6.4
webb06's Avatar
black onyx. this time im gunna put oem Ford back on it
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #5 of 9 (permalink) Old 06-08-2011, 02:35 AM
2006.1f250's Avatar
I had fire rings fail on my 06 twice. First time only the head was cut. The second time, we cut the head and the block. Don't know why they failed, but not going to give it a third try. We are going back to a stock head gasket and two flat surfaces. My suggestion would be, stock head gaskets and machine the block and heads flat.
2006.1f250 is offline
post #6 of 9 (permalink) Old 06-08-2011, 02:46 AM
Administrator
Zmann's Avatar
but that required a full tear down correct
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 9 (permalink) Old 06-08-2011, 03:03 AM
NoSlow6.0's Avatar
I had my heads o ringed with the Wide Open Performance kit. I was told the reason most 6.0 o ringed heads failed was people were using the wrong head gasket. You might want to check with them and see what they say.
10's ???
NoSlow6.0 is offline
post #8 of 9 (permalink) Old 06-08-2011, 04:59 PM
I agree on going back to oem head gaskets :)
web, is your warranty over?
Also, get the STC updated, fuel reg, turbo lines.
smokersteve is offline
post #9 of 9 (permalink) Old 06-09-2011, 02:18 AM
2006.1f250's Avatar
If this question is for me, yes, it was a complete tear down to groove the block.
There's a difference between o-rings and fire rings. I don't know how Wide Open does there kits, but a stock head gasket was modified for the fire rings. I'll look at the Wide Open stuff just out of curiosity.
