turbo install tips - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-04-2011, 01:43 AM Thread Starter
379cat's Avatar
turbo install tips
im putting my bd thruster in with the diverter, im having a heck of a time getting a wrench on the exhaust flang bolts, you guys got any tips? is it possible to put the turbo and the mount in all together, cause this sure bites trying to get these bolts tight, i feel stupid for asking this but iv taken my cab off in alot less time then iv put into installing this turbo today lol
99 ford superduty started its life with a 5.4 triton, now its got a 05 6.0 powerstroke in it , BD thruster turbo, RCD 175 cc injectors, ARP studs, black onyx gaskets inovative tunes. homade egr delete. homade RR fuel system fass 150 pump, suncoast trans kit ran 13.4 fuel only
379cat is offline
post #2 of 14 (permalink) Old 06-04-2011, 01:52 AM
Almost broke
midnight2004's Avatar
Re: turbo install tips
I took a box end wrench 15mm (I think) and bent it to tighten the nuts. I know what you're talking about..... nice kit but a PIA to install.
let me know how that diverter valve works
Chris
2004 F250 Lariat 6.0L
Torqueshift, 4x4, Supercab, Shortbox.
midnight2004 is offline
post #3 of 14 (permalink) Old 06-04-2011, 03:08 PM
i like to party
pizza pig's Avatar
what are the specs of the BD thruster with the new diverter?
let us know how it runs with the 175's
pizza pig is offline
post #4 of 14 (permalink) Old 06-04-2011, 11:46 PM
Best tip I can give you-leave the rearmost turbo bolt out-lol-its a PITA. Feel around, its tough to get to and nearly impossible to see. Make sure to use 6 point sockets as any bolt that has seen as many heat cycles as those have is bound to be seized something fierce, and 12 points have a propensity for stripping. Remove the Degas bottle, and unclip the harness from the loom directly above the turbo. Remove the loom and tie the harness up. Take the intake out in one piece, not the ends/filter seperately. Remove the oil line at the intake to avoid replacing the gasket (I guess you'll be chaning it anyway) and use plenty of penetrating oil/allow it to soak before attempting. Loosen both up-pipes, start the y-pipe on the turbo and tighten it down. Then tighten the downpipes. Makes alignment much easier, and prevents leaks from the turbo inlet not sealing to the y-pipe. Any questions, PM me!
ddillenger is offline
post #5 of 14 (permalink) Old 06-05-2011, 12:06 AM
After your all done, leave the turbo feed line off the turbo, pour oil down the feed hole, then put the line back on the turbo, star the truck. And take your time :)
smokersteve is offline
post #6 of 14 (permalink) Old 06-05-2011, 01:54 AM Thread Starter
379cat's Avatar
I won't get to work on it again till the end of next week but it is a pita for sure! If it didn't have the diverter valve I don't think it would be that bad, you can't even get a socket. On any of these nuts... heck you can't even get a wrench on 2 of em lol.. I'm about to jack the cab up lol if I ever get these bolts tight I will let you guys now how it works lol
379cat is offline
post #7 of 14 (permalink) Old 06-05-2011, 12:10 PM
Extended Power's Avatar
Jeezz...things to look forward to...
I had to put mine in as well just to got the up pipes lined up before I welded the new stainless steel bellows in. It was fun just getting the whole bracket, and adaptor flanges on...
2003 F-350 KingRanch 4x4
Extended Power is offline
post #8 of 14 (permalink) Old 06-05-2011, 02:23 PM
Banned
I'm going to try to put mine in with the t4 adapter alreAdy on
donzimama is offline
post #9 of 14 (permalink) Old 06-05-2011, 02:29 PM Thread Starter
379cat's Avatar
You don't have the diverter do ya? That shouldn't. Be to bad
379cat is offline
post #10 of 14 (permalink) Old 06-05-2011, 02:34 PM Thread Starter
379cat's Avatar
Lol let me know how many times you drop the flange. Nuts down in the valley trying to get em. Started with your fingernails think I was up to like 30 times lol.
379cat is offline
