proper oil pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-02-2011, 03:45 AM Thread Starter
i like to party
pizza pig's Avatar
proper oil pressure
What is the proper warm and cold idling pressures in the LPOP? I've done research and havent really found solid numbers to verify my readings, anyone wanna chime in?
Im seeing
20ish PSI warm idle
90ish PSi cold idle
60ish PSI cruising
pizza pig is offline
post #2 of 6 (permalink) Old 06-02-2011, 05:31 PM
Re: proper oil pressure
minimums per ford,
12 psi @700 rpm
24 psi @1200 rpm
45 psi @1800 rpm
with engine at op temp.
skippy is offline
post #3 of 6 (permalink) Old 06-02-2011, 05:34 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
90 psi is really high even cold... I would expect to see about 70-75psi cold. Otherwise I have my warning lights set to come on at 20psi. Rarely comes on.
Joe
CSIPSD is offline
post #4 of 6 (permalink) Old 06-02-2011, 09:38 PM Thread Starter
i like to party
pizza pig's Avatar
thats only a wintertime (teens in temp) cold start it slowly drops. I need to look tomorrow at the cold start when its warmer out.
post #5 of 6 (permalink) Old 06-02-2011, 10:13 PM
Administrator
Zmann's Avatar
what oil ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 6 (permalink) Old 06-02-2011, 11:22 PM Thread Starter
i like to party
pizza pig's Avatar
T5 10w30
