FICM and ECM/TCM rollback - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-29-2011, 09:57 PM Thread Starter
Is this something I need to do with a 2003 Dually 6.0? It's a stock truck and runs great. Just was suggested and I haven't heard of it before.
Thanks
Dave
2003 Fire engine red F350 6.0 CCLB DRW Lariat.
Blue fuel spring, coolant filter, EGR delete, Banjo bolts, Rotella T 5-W40, ARP, DE 4" turbo back, Farmers 175/75's, SCT with Vivian's tunes.
Dave R is offline
post #2 of 8 (permalink) Old 05-29-2011, 11:54 PM
bring the chain
kyle43335's Avatar
Re: FICM and ECM/TCM rollback
Thanks
Dave
Never heard of this rollback.
kyle43335 is offline
post #3 of 8 (permalink) Old 05-30-2011, 02:06 AM
Power Junky
Lubbockguy1979's Avatar
It all depends on your pcm and ficm strategy. The strategy is basically the factory tuning designation. Most believe the earlier strategies had the most power and best mpg. As ford added updates mpgs went to crap and so did power.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
post #4 of 8 (permalink) Old 05-30-2011, 02:46 AM
Groovy Chick's Avatar
There are four ECM strategies that have poor performance output, and rolling them back to a preferred strategy can correct that issue. Bill (at PHP) dynoed our 6.0L this weekend with one of the crappy strategies and then again with one of the preferred strategies. He'll be posting dyno plots on our website since we are frequently asked what exactly is the benefit of rolling back an ECM. (In addition, customers who have their FICMs reprogrammed don't always see the optimum results of FICM tuning if they have a poor ECM strategy.)
The dyno plots should be on our website later this week (maybe even as early as tomorrow). I'll try to update this thread as soon as I have any info.
Originally Posted by 444-4D View Post
The reason you can't get any radio stations is so it will be quiet enough in the cab to hear your rods escape.
Groovy Chick is offline
post #5 of 8 (permalink) Old 05-30-2011, 03:23 AM Thread Starter
That's great news. So I need to get an Oasis report and it'll tell me if I've had adjustments and if so, I'm more than likely suffering some in performance?
Thanks for the info. Can't wait to see the difference.
DAve
Dave R is offline
post #6 of 8 (permalink) Old 05-30-2011, 06:17 PM
Administrator
Zmann's Avatar
The Oasis may not spell out the strategy,, someone with an SCT can read your strategy for you or an A/E etc or the dealer but that may cost you
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 8 (permalink) Old 05-30-2011, 06:56 PM Thread Starter
It has the following repair. Looks like it was reprogrammed but it was in 04 when they did it. Does that matter?
-CK SEEMS TO RUN ROUGHER THHAN NORMAL LACKS POWER
-REPROGRAMMED PCM,TCM & FICM EEC (QUICK TEST) DIAGNOSIS PER SSM 17567
This one is from 06
-CUST STATES LACKS POWER WHEN ACCELS HWY SPEEDS, WORSE WHEN COLD
-REFLASH PCM TO 3U7A 12A650 FTF.6.0 PERFORMANCE DIAG STEPS 1 10A,11,13,VGT TEST,FOUND LOW BOOST,CLEANED VGT SOLENOID,VALVE NOW OPERATES PROPERLY,NO NEED FOR REPLACEMENT AT THIS TIME.CLEARED CODES(P0299),ROAD TEST,RECHECK,NO FURTHER PROBLEMS NOTED
Another from 06
-CUSTOMER STATES THAT THE 06E17 IS DUE
-PERFORMED 06E17, REPROGRAMMED PCM, AND TCM
New turbo in 06 which is good and explains the reman tag on the turbo.
Injectors 2 and 8 were replaced in 08. Otherwise, everything looks good.
What do you guys think??
Dave
Dave R is offline
post #8 of 8 (permalink) Old 05-30-2011, 07:00 PM Thread Starter
Actually, these are all from the same visit in 06 and the intercooler was swapped too for a seal.
Dave R is offline
